Konnected inverse binary sensor
Hi all,
I just received my Konnected kit and set it up. Works fine as far as detecting the state changes. My only problem is that the binary sensor I’m setting up in HA (using the UI integration configuration) is inverted, i.e. shows “closed” when the window is open and “open” when the window is closed. I’ve tried the inverse setting, but it doesn’t seem to make any difference. Running v.0.111.4.
Anyone else facing similar issues? Any suggestions?
Thank you
@heythisisnate, any ideas?
Never mind; I just upgraded to v.0.112.2 and it seems to have solved the problem. Thanks anywyay.
