@Crhass I finally was able todo this steps, set up WiFi . Could you share your Yaml. I can’t see anything in my HA after reboot.
You have configured 2 konnected units with that yaml. You need to set the Id so it matches your Mac address of your konnected.
I did this is the YAML code. What should I see in HA after the reboot? Thanks for the reply
konnected:
access_token: Konnected
devices:
- id: 600194
binary_sensors:
- zone: 1
type: door
- zone: 3
type: motion
switches:
- zone: out
If the konnected board is powered up you should see your 2 binary sensors apear and a switch.
You need to have discovery turned on in HA but it is usually on by default.
If it still doesn’t work, try going back to your original access_token as I noticed you changed it. Or reflash your konnected board again.
done was MAC address needed to be all MAC not 6 caracter
