Wondering if anyone can help. Have a konnected alarm panel with various sensors set up. Since I managed to get external access going again the konnected panel sensors are displaying their status as “Unknown”.
Not sure why. I’ve set the override API host URL to https://[home assistant ip address]:8123 restarted home assistant, but the sensors remain unknown.
I can ping the thing so assume its on my network. I am running firmware 2.3.5. Was working fine before I finally got external access via duckdns back up and running.
I’ve restarted home assistant, restarted the Konnected device, removed the integration hoping it would be detected. No luck. Can’t add it manually as I don’t know what port number to use.
Any ideas? I’d sure like to hear em.
*** update ***
Home assistant has recognised the Konnected Alarm Panel:
but it “failed to set up”: This is what I see in the logs:
Logger: homeassistant.config_entries
Source: helpers/network.py:116
First occurred: 12:59:36 (1 occurrences)
Last logged: 12:59:36
Error setting up entry Konnected Alarm Panel for konnected
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 327, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/konnected/__init__.py", line 260, in async_setup_entry
await client.async_connect()
File "/usr/src/homeassistant/homeassistant/components/konnected/panel.py", line 133, in async_connect
await self.async_sync_device_config()
File "/usr/src/homeassistant/homeassistant/components/konnected/panel.py", line 374, in async_sync_device_config
self.async_desired_settings_payload(),
File "/usr/src/homeassistant/homeassistant/components/konnected/panel.py", line 335, in async_desired_settings_payload
self.hass.data[DOMAIN].get(CONF_API_HOST) or get_url(self.hass)
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 116, in get_url
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
Reconfigured all zones, restarted home assistant. All sensors remain in an “Unknown” state.
