I’ve just migrated my Konnected alarm from the custom integration to ESP Home. I thought I’d try to compile my own firmware, but can’t see where I’ve gone wrong. Only the Kitchen PIR, Utility Room PIR and Tamper trigger. The rest do nothing. I’m new to ESP code, so I expect I’ve made every mistake going - and hoping someone will tell me where my mistake is.
# GENERAL SETTINGS
# Customize these variables to your preferences and needs
# more: https://esphome.io/guides/configuration-types.html#substitutions
substitutions:
# NAME
# By default, the name of the ESPHome device is "konnected-xxxxxx" where xxxxxx is a unique identifier. The device's
# hostname on your network is also defined by the name, defaulting to "konnected-xxxxxx.local". Edit this variable to
# customize the name and hostname. Note: only lowercase characters, numbers and hyphen(-) are allowed.
friendly_name: Alarm Panel Pro
project_name: konnected.alarm-panel-pro-ethernet
project_version: "0.1.CUSTOM"
# ETHERNET CONFIG
# On the Alarm Panel Pro v1.5, v1.6 and v1.7 use LAN8720. On the v1.8 set this variable to RTL8201.
ethernet_type: LAN8720
sensor_debounce_time: 200ms
warning_beep_pulse_time: 100ms
warning_beep_pause_time: 130ms
warning_beep_internal_only: "false"
warning_beep_shared: "false"
blink_on_state: "true"
# ZONE MAPPING
# Do not edit this section.
zone1: GPIO4
zone2: GPIO2
zone3: GPIO15
zone4: GPIO13
zone5: GPIO18
zone6: GPIO14
zone7: GPIO33
zone8: GPIO32
zone9: GPIO36 # working
zone10: GPIO39 # working
zone11: GPIO34 # not tested
zone12: GPIO35 # working
alarm1: GPIO12
alarm2: GPIO5
out1: GPIO23
out2: GPIO5
status_led: GPIO3
# CONNECTION MAPPINGS
warning_beep_pin: $out1
# PACKAGES
# Each package includes the alarm panel feature
# Remove or comment out any packages that you do not need or want.
# If you're developing/installing locally, replace the github package line with the local package include above it.
packages:
remote_package:
url: https://github.com/konnected-io/konnected-esphome
ref: master
refresh: 5min
files:
# CORE
# This package is required and sets up core features.
- packages/core-esp32.yaml
# ETHERNET
# Enables ethernet connectivity.
- packages/ethernet.yaml
# MDNS
# Enables the _konnected MDNS/zeroconf service advertisement needed for the Konnected App
- packages/mdns.yaml
# STATUS LED
# Enables the onboard blue status LED as an activity/error indicator
- packages/status-led.yaml
# INPUT ZONES
- packages/alarm-panel/zone1.yaml
# WARNING BEEP
# Enables a 'Warning Beep' entity, intended to be used with a piezo buzzer or other pulsing.
# binary output This is implemented using the light component with strobe effect to create a
# repeated beeping sound or pulsing action that can be turned on via the _strobe_ effect.
- packages/warning-beep.yaml
dashboard_import:
package_import_url: github://konnected-io/konnected-esphome/alarm-panel-pro-esp32-ethernet.yaml@master
import_full_config: false
# WEB SEVER
# Enables the built-in web server for viewing the device state, internals and controls via web browser
# on the same local network as the device.
web_server:
include_internal: true
# LOGGER
# more: https://esphome.io/components/logger.html
logger:
# NATIVE API for HOME ASSISTANT
# Enables the native API for Home Assistant
# more: https://esphome.io/components/api.html
api:
encryption:
key: xxxxxxx
ota:
- platform: esphome
password: "xxxxxxx"
binary_sensor:
#2
- platform: gpio
name: Sitting Room PIR
device_class: motion
pin:
number: $zone2
mode: INPUT
filters:
- delayed_on_off: $sensor_debounce_time
on_state:
- if:
condition:
lambda: return id(blink_on_state);
then:
- script.execute: blink_status_led
#3
- platform: gpio
device_class: door
pin:
number: $zone3
mode: INPUT
on_state:
- if:
condition:
then:
#4
- platform: gpio
name: Drawing Room PIR
pin:
number: $zone4
mode: INPUT
on_state:
- if:
condition:
then:
#5
- platform: gpio
device_class: door
pin:
number: $zone5
mode: INPUT
on_state:
- if:
condition:
then:
#6
- platform: gpio
pin:
number: $zone6
mode: INPUT
on_state:
- if:
condition:
then:
#7
- platform: gpio
name: Upstairs PIR 1
pin:
number: $zone7
mode: INPUT
on_state:
- if:
condition:
then:
#8
- platform: gpio
name: Upstairs PIR 2
pin:
number: $zone8
mode: INPUT
on_state:
- if:
condition:
then:
#9
- platform: gpio
name: Utility Room PIR
pin:
number: $zone9
mode: INPUT
on_state:
- if:
condition:
then:
#10
- platform: gpio
pin:
number: $zone10
mode: INPUT
on_state:
- if:
condition:
then:
#11
- platform: gpio
device_class: tamper
pin:
number: $zone11
mode: INPUT
on_state:
- if:
condition:
then:
#12
- platform: gpio
pin:
number: $zone12
mode: INPUT
on_state:
- if:
condition:
then:
- platform: homeassistant
entity_id: input_boolean.test_switch
switch:
- platform: gpio
icon: mdi:alarm-bell
pin: $alarm1
# - platform: gpio
# id: buzzer
# name: Buzzer
# icon: mdi:bell-ring-outline
# pin: $out1
alarm_control_panel:
platform: template
codes:
- "1234"
requires_code_to_arm: false
arming_away_time: 0s
arming_home_time: 0s
pending_time: 15s
trigger_time: 1min
binary_sensors:
- input: sitting_room_pir
bypass_armed_home: true
trigger_mode: instant
- input: front_door
trigger_mode: delayed
- input: drawing_room_pir
- input: kitchen_door
chime: true
- input: study_pir
- input: upstairs_pir1
bypass_armed_night: true
- input: upstairs_pir2
- input: utility_room_pir
- input: kitchen_pir
- input: panic
trigger_mode: instant_always
- input: tamper
on_state:
then:
- lambda: !lambda |-
ESP_LOGD("TEST", "State change %s", alarm_control_panel_state_to_string(id(acp1)->get_state()));
on_triggered:
then:
- switch.turn_on: siren1
on_cleared:
then:
- switch.turn_off: siren1
on_ready:
then:
ESP_LOGD("TEST", "Sensor ready change to: %s",
(id(acp1).get_all_sensors_ready()) ? (const char *) "True" : (const char *) "False");
on_chime:
then:
ESP_LOGD("TEST", "Zone with chime mode set opened");
However, when using the basic code, all PIRs trigger:
# GENERAL SETTINGS
substitutions:
# NAME
project_version: "1.2.1"
# ETHERNET CONFIG
# ZONE MAPPING
zone1: GPIO4
zone2: GPIO2
zone3: GPIO15
zone4: GPIO13
zone5: GPIO18
zone6: GPIO14
zone7: GPIO33
zone8: GPIO32
zone9: GPIO36
zone10: GPIO39
zone11: GPIO34
zone12: GPIO35
alarm1: GPIO12
alarm2: GPIO5
out1: GPIO23
out2: GPIO5
status_led: GPIO3
# PACKAGES
packages:
remote_package:
ref: master
refresh: 5min
files:
# CORE
# ETHERNET
# MDNS
# STATUS LED
# INPUT ZONES
- packages/alarm-panel/zone2.yaml
- packages/alarm-panel/zone3.yaml
- packages/alarm-panel/zone4.yaml
- packages/alarm-panel/zone5.yaml
- packages/alarm-panel/zone6.yaml
- packages/alarm-panel/zone7.yaml
- packages/alarm-panel/zone8.yaml
- packages/alarm-panel/zone9.yaml
- packages/alarm-panel/zone10.yaml
- packages/alarm-panel/zone11.yaml
- packages/alarm-panel/zone12.yaml
# OUTPUTS
- packages/alarm-panel/alarm1.yaml
- packages/alarm-panel/alarm2.yaml
# WARNING BEEP
dashboard_import:
# WEB SEVER
web_server:
# LOGGER
logger:
api:
