**** Update: It’s working: The API address should read https://[ip address]:[port]. ****
**** Leaving this here in case someone else has the same issue. ****
Having a real hard time getting the Konnected board to work.
I’m fairly confident it is on my WIFI as I am pinging it successfully, I am also able to browse the panel’s page on the local network. It just will not update in Home Assistant.
I’ve been trying to resolve this over the last two days. Here is what I have done:
- Disconnected and reconnected WIFI multiple times;
- Changed the API Endpoint from duckdns to ip address:8123 (now reads http://192.168.1.24:8123/api/konnected).
- Deleted and re-installed the Konnected integration multiple times;
- Re-flashed to the device (Software 2.3.5 - Firmware 2.3.0);
- Checked the WIFI signal (Page reports Wifi Signal Strength as 100%).
Note: I flashed the device with konnected-firmware-2-3-5.bin, yet the page reports the firmware as 2.3.0.
It also seems to randomly disconnect itself from WIFI.
Is there anything I’ve overlooked?
Any help with this would be awesome as I’ve run out of ideas.
Not sure is this is relevant, but when I type in the API address into the browser, the get a connection error…
