Kruidvat SMART outdoor plug
Hi guys,
I just created an esphome configuration for a Kruidvat Smart outdoor plug art.nr. SH.33.407 since i couldn’t find an ESPHOME configuration for on the internet. Maybe someone can put this info to use, or it can safe someone so valuable some time. Price of the IP44 outdoor plug is only 10 euro.
The plug can be fairly easy opened by twisting and pulling the green rubber cap (IP44) off. Then 2 triangle security screws are reveiled that hold the 2 black plastic parts together.
Inside is a small CB2S chip which can be flashed with ESPHOME.
Pinout can be found here: CB2S - LibreTiny
I desoldered the small chip from the board and flashed it with the configuration below:
esphome:
  friendly_name: OutdoorPlug
bk72xx:
  board: cb2s
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxx"
ota:
  - platform: esphome
    password: "xxxxx"
# Enable Web server.
web_server:
  port: 80
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Outdoorplug Fallback Hotspot"
    password: "xxxxx"
captive_portal:
# Code below is specific for Kruidvat SMART outdoor plug
# art.nr: SH.33.407
# The main relay is connected to P24
switch:
  - platform: gpio
    pin: P24
    on_turn_on:
      then:
        light.turn_on: greenled
    on_turn_off:
      then:
        light.turn_off: greenled
  - platform: gpio
    pin: P6
    inverted: true
# The button on the side of the socket is wired to P8
binary_sensor:
  - platform: gpio
    pin:
      number: P8
      mode:
        input: true
        pullup: true
      inverted: true
    on_click:
      min_length: 50ms
      then:
        switch.toggle: socket1
# The LED is directly controlled via the state of the relay with the switch above
light:
  - platform: binary
    output: greenled_output
    internal: true
output:
  - id: greenled_output
    platform: gpio
    inverted: true
    pin: P7
interval:
  - interval: 30sec
    then:
      if:
        condition:
          not:
            - wifi.connected:
        then:
          switch.turn_on: redled
        else:
          switch.turn_off: redled
thanks for the tip!
ordered a couple for my garden. will also try to flash them.
