Kwikset 888 Alarm Level/Type/Status Resets Lock to Incorrect State
I recently added a Kwikset 888 to my HA setup and seem to have issues with status reporting. I’ve read through a few other posts (there are many), so apologies if this has already been answered. I’ll note all other z-wave devices are functioning/reporting properly.
Issue:
When HA restarts, the Alarm Level and Type set to 0 (which is No Status Reported). This causes the lock to report a Locked state and a notification of “Manual Lock”, even when physically unlocked. Though, the lock_status is correct. If the “unlock” button is pressed from Lovelace, the state will update, even though the lock won’t physically do anything since it’s already unlocked. I’ll also note if the lock state is changed through the physical keypad or thumb-turn, the state is immediately reported correctly.
Troubleshooting:
  • Refreshed node in Z-Wave Configuration
  • Disabled Automations from lock-manager plugin (see below)
HA Setup:
  • HomeAssistant running in Virtual Machine on unRAID
  • Version 2020.12.7 for both Core and Supervisor (has persisted since .118)
  • Standard Z-Wave Integration (not OZW Beta)
  • Using lock-manager from FutureTense
Z-Wave Network:
  • GoControl CECOMINOD016164 HUSBZB-1 USB stick
  • Aeotec Range Extender 6 (QTY 1)
  • This Kwikset 888 Lock (Added Securely)
  • GE (Jasco) Dimmer (QTY 1)
  • GE (Jasco) Switch (QTY 1)
  • GE (Jasco) Fan Control Switch (QTY 1)
Thanks in advance for any pointers!
