Perhaps a year ago I purchased a Kwikset Halo Select and successfully commissioned it in Home Assistant using Matter over Thread. Unfortunately, so many features were missing at the time that I converted back to Wi-Fi and used the Halo app.
Forward to recent weeks and I saw an announcement of improved support for lock codes in Matter on Home Assistant. I have tried several times to switch the lock back to Thread but it will not fully connect.
Important fact: the hub attached to my Home Assistant Yellow is my only hub. Google and Apple are not options.
The process has been:
- Convert lock to matter using the Halo app
- Start the connection process
- Select “other” after Google/Apple/Samsung/whatever
- Choose Home Assistant
- Ignore HA’s warning that Kwikset recommends their own process
- Scan QR code (possibly before the warning)
- Lock connects
- Credentials are generated
- Hangs on the “Checking connectivity to Thread network ha-thread-xxxx” screen
This is not my first time commissioning a matter device - I have 35 matter devices, almost all using Thread. The lock is less than 20 feet from the hub and 2 feet from an Eve wall switch which acts as a router.
I just can’t make this one work.
The warning about using the manufacturer’s preferred method looks like a red flag, but I don’t see any other options in the app which don’t require a hub from one of the big web companies.
Has anyone successfully connected directly to Home Assistant? Other suggestions?
