I just installed Home Assistant and so far the only ZWave device I have paired is not functioning properly. I’m using an Aeon Z-stick on Ubuntu 14.04, and having followed the installation instructions on this site I can actually see a device called simply “Lock” in the Home Assistant home screen. The trouble is toggling it doesn’t seem to actually do anything. It doesn’t even update the log you get when mousing over the “unlocked” portion of the device.
I can’t find any errors in homeassistant.log. I just see the following lines whenever I try to toggle the lock (id X’ed out):
homeassistant.core: Bus:Handling <Event call_service[L]: service_call_id=XXXXXXXXXXXX-4, service=lock, domain=lock, service_data=entity_id=lock.__locked_2>
homeassistant.core: Bus:Handling <Event service_executed[L]: service_call_id=XXXXXXXXXXXX-4>
The history tab simply states “No state history found.”
