Is anyone else having trouble with their La Mazocco integration since upgrading the firmware/gateway? Using with a Micra and tried re-configuring and re-adding with no success.
Yes, same thing… I just figured out that there is an update of this integration which possibly solves this, but I’m not sure how to install a integration pre-release. if someone can share a link / howto would be useful… release 1.4.9
There are no open issues on the integration according to the HA Docs.
Perhaps someone should write an issue so it could be fixed?
¯\(ツ)/¯
Reporting issues - Home Assistant.
GitHub · Where software is built.
it is fixed in the latest 2025.3.4 Version of HomeAssistant. Don’t enter a IP-Address when requested. It will directly connect to the cloud since local access does not work anymore
thanks. can confirm its now working with the new update.
