For what it’s worth, I changed my endpoint url to be intentionally incorrect and with all green checks, it give me the same error below. Please check the url endpoint in the dev skill app to make sure its correct in your setup.
The remote endpoint could not be called, or the response it returned was invalid.
well I ran into another problem but not sure why last night I just tested the phase “where are we” and I got a answer.
today I tested and it still worked but then I asked where Cathy was and I got the same Error as before
Could it have to do with notify I’m using pushbullet
any time Iask where we are I get the right response
You can try comment out that part of the intent section to try to make it more like the working Wherearewe. I don’t use notify or cards.
LocateIntent:
# action:
# service: notify.notify
# data_template:
# message: The location of {{ User }} has been queried via Alexa.
speech:
type: plaintext
text: >
{%- for state in states.device_tracker -%}
{%- if state.name.lower() == User.lower() -%}
{{ state.name }} is at {{ state.state }}
{%- elif loop.last -%}
I am sorry, I do not know where {{ User }} is.
{%- endif -%}
{%- else -%}
Sorry, I don't have any trackers registered.
{%- endfor -%}
# card:
# type: simple
From helping you, I decided to rework my Alexa skill which you might like. Instead of calling it “home assistant”, I called it “location” and rewrote the intents so this works
Alexa, tell location of User1
Alexa, ask location of User1
Alexa, search location of User1
I will write a skill called “status” today to report sensor info.
@RobDYI Have you had any luck with the sensor status skill? I would be very interested in if you could share your configeration as I have about 8 temp sensors around the house.
I did get the location skill to work, But after she tells me the location, She says she don’t know where I am
Not sure why you get the I am sorry part. Mine is the exact same and works. You can always delete that part of the speech or write something else.
speech:
type: plaintext
text: >
{%- endif -%}
{%- else -%}
{%- endfor -%}
I haven’t wrote the sensor state skill yet but I think this one fits your needs. I’ll post mine when complete.
@RobDYI Well I find why it was saying the I am sorry part, look at {%- elif loop.last -%} I copied from above
LocateIntent:
data_template:
speech:
type: plaintext
text: >
{%- endif -%}
{%- else -%}
{%- endfor -%}
And I got the Status of my sensors for now, when ever you get yours done please let me know.
Thanks for all your help, I learned a lot the last few days.
