Having issues getting the value I want from what seems to be a simple lambda.
I have these two actions to set the text opacity of some Labels. I want some labels a bit dimmer than others so I thought I could just subtract 15 from the “clock_text_opacity” value before applying the scaling factors for text_opa.
As it sits, it compiles and deploys with no issues. The problem is the second one doesn’t return the correct value. What I want is to subtract 15 from “clock_text_opacity” before applying the scaling factors. Due to order of operations, what’s happening is it’s first dividing 15 by 100, then multiplying by 255, then subtracts that value from the “clock_text_opacity” value.
So I figured it just needed some parentheses in the correct place to force it to subtract 15 from “clock_text_opacity” and then apply the scaling. Problen is every place I add them it won’t compile.
If I change the equation to
!lambda return id((clock_text_opacity).state - 15) / 100 * 255;
it returns the error shown below the code snippet.
Any ideas?
number:
optimistic: true
unit_of_measurement: "%"
initial_value: 100
restore_value: true
min_value: 1
max_value: 100
step: 1
mode: box
on_value:
then:
- lvgl.label.update:
id:
- header_display_time
- page_prev
- page_home
- page_next
- display_time
- display_temperature
- display_humidity
- display_pressure
- display_pressure_trend
- display_pm25
- display_pm10
- display_co2
text_opa: !lambda return id(clock_text_opacity).state / 100 * 255;
# Desired value needs to be scaled from a percent, then to a 0-255 range
id:
- display_pm25_id
- display_pm25_units
- display_pm10_id
- display_pm10_units
- display_co2_id
- display_co2_units
text_opa: !lambda return id(clock_text_opacity).state - 15 / 100 * 255;
/config/esphome/livingroom-clock.yaml: In lambda function:
/config/esphome/livingroom-clock.yaml:764:74: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
then:
/config/esphome/livingroom-clock.yaml:765:77: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
/config/esphome/livingroom-clock.yaml:766:74: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
id:
/config/esphome/livingroom-clock.yaml:767:77: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
/config/esphome/livingroom-clock.yaml:768:73: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
- page_prev
/config/esphome/livingroom-clock.yaml:769:76: error: request for member 'state' in 'clock_text_opacity', which is of pointer type 'esphome::template_::TemplateNumber*' (maybe you meant to use '->' ?)
- page_home
*** [.pioenvs/livingroom-clock/src/main.o] Error 1
