Lanbon L8 issue need help
Am fairly new to HA and am really loving it
i got a lanbon L8 and was able to flash openHasp firmware on it.
the problem is the entities will not load and therefore i cant set automations or anything
here is my openhasp.yaml file
  richards_office:
    objects:
      - obj: "p0b1"  # temperature label on all pages
        properties:
          "text": '{{ states("sensor.downstairs_current_temperature_2") }}°C'
      - obj: "p1b2"  # light-switch toggle button
        properties:
          "val": '{{ 1 if states("light.my_room") == "on" else 0 }}'
          "text": '{{ "\uE6E8" if is_state("light.my_room", "on") else "\uE335" | e }}'
        event:
          "up":
            - service: homeassistant.toggle
              entity_id: "light.my_room"
      - obj: "p1b3"  # dropdown
        event:
          "changed":
            - service: persistent_notification.create
                message: I like {{ text }}
Hello Richie-f,
Thanks for coming here and asking a question.
Would you be so kind as to adjusting the format of your code so that we can read it properly & check the YAML spacing, etc. Editing your original is the preferred way. It is very hard for us to tell what is what when the text formatter jumbles everything like that.
Use the </> button or this:
Here is an example of how to fix it from the site FAQ Page.
How to help us help you - or How to ask a good question.
Thank you @Sir_Goodenough ,… sorry i thought i did
  richards_office:
    objects:
        properties:
        properties:
        event:
          "up":
        event:
          "changed":
everything seems to look right to me but still no dice
