axydas
(Andreas)
1
Hi
I have a 3d printer that does not support standby mode so when the printer is off the sensors in home assistant becomes unavailable
Is there an easy way to create a sensor to keep the last known value and ignore the unavailable or unknown state?
One option would be to use a trigger-based template sensor with a State trigger that only listens for your desired states.
template:
- trigger:
- trigger: state
entity_id: sensor.printer_mode_example
to:
- 'on'
- printing
- idle
- name: 3D Printer Mode
state: "{{ trigger.to_state.state }}"
WallyR
(Wally)
3
Or instead of the to: section you could use
not_to:
- unavailable
