Last Updated info is being reset after HA starts
Hi all,
Can you please help me? :grinning:
I have a switch which stays ON only for 1 seconds and then goes OFF automatically.
I need to calculate the time difference between “now” and “the time it went ON”. So I can write it as info on the cards. For example: “34 minutes ago”
I managed it with below code but every time HA restart timer is reset to HA start time. I want it to show always delta from the last time the switch was ON, not the delta from HA starts.
template:
  - trigger:
      - platform: state
        entity_id: switch.driveway
        to: 'on'
      - name: driveway_on
        state: "{{ now().timestamp() | timestamp_custom('%I:%M %p %a') }} "
Card info
{{ relative_time(states.sensor.driveway_on.last_changed) }}
Thanks.
Because the sensor gets triggered by every from state to on.
      - platform: state
        to: 'on'
should avoid this.
I believe some have a boolean “restore” property meant for this - could be that
Thanks but that didn’t work
What exactly did not work?
Alternatively, you can add
not_from:
- unavailable
- unknown
- none
- null
P.S.: You mentioned 2 sensors, sensor.driveway_on and sensor.light_on. Do they follow the same structure?
I have 1 sensor. Sorry for the typo. I fixed it.
It didn’t work because, when HA starts, It updated the sensor not the state of switch. So “states.sensor.driveway_on.last_changed” is always equals to HA start time. I need to solve this but How?
Somehow, I need to write somewhere the time “the switch goes ON”, then minus from now. And “time the switch goes ON” should not be overwritten when HA restarts.
Note: default state of switch is OFF
The state of the sensor should catch the real last change of your switch (but I highly recommend to add a from state to the trigger).
Solution:
Config yaml
template:
  - trigger:
      - platform: state
        to: 'on'
      - name: driveway_on
        state: "{{ now().timestamp()}}"
Card info
{{ relative_time(states.sensor.driveway_on.state | as_datetime)
@pedolsky Thank you mate!
