Latest version for rasbperry pi 3b doesnt install
So i initially updated home assistant to the latest update and it stopped working altogether, so i started from scratch. Installed clean using the raspberry pi imager on an sd card and i cant make it work:
Full log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[16:22:15] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[16:22:15] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
24-02-27 16:22:39 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-27 16:22:39 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
24-02-27 16:22:43 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64
24-02-27 16:22:43 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.02.0
24-02-27 16:22:43 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-02-27 16:23:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-27 16:23:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 16:23:17 INFO (MainThread) [__main__] Setting up Supervisor
24-02-27 16:23:17 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-27 16:23:17 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-27 16:23:24 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-27 16:23:34 WARNING (MainThread) [supervisor.utils.dbus] Busy system at org.freedesktop.timedate1 - /org/freedesktop/timedate1
24-02-27 16:23:47 WARNING (MainThread) [supervisor.utils.dbus] Busy system at org.freedesktop.timedate1 - /org/freedesktop/timedate1
24-02-27 16:24:00 WARNING (MainThread) [supervisor.utils.dbus] Busy system at org.freedesktop.timedate1 - /org/freedesktop/timedate1
24-02-27 16:24:03 ERROR (MainThread) [supervisor.utils.dbus] Could not get introspection data after 3 attempts
24-02-27 16:24:03 WARNING (MainThread) [supervisor.dbus.timedate] Can't connect to systemd-timedate
24-02-27 16:24:03 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-27 16:24:03 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-27 16:24:12 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-27 16:24:15 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-27 16:24:49 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-27 16:24:49 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-27 16:24:49 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-27 16:24:50 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2023.11.0'>]
24-02-27 16:24:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-02-27 16:24:52 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-27 16:25:46 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-27 16:25:47 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
24-02-27 16:25:47 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-27 16:25:51 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-27 16:27:08 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-27 16:27:08 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-27 16:27:08 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
24-02-27 16:27:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-02-27 16:27:10 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-27 16:28:34 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-27 16:28:34 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
24-02-27 16:28:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-27 16:28:37 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-02-27 16:29:56 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-02-27 16:29:56 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
24-02-27 16:29:56 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-27 16:29:58 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-27 16:32:50 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-02-27 16:32:51 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-27 16:32:51 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
24-02-27 16:32:51 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
24-02-27 16:32:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-02-27 16:32:51 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
24-02-27 16:33:30 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-27 16:33:33 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-02-27 16:34:38 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-02-27 16:34:38 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.0 / BootSlot A
24-02-27 16:34:38 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
24-02-27 16:34:39 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
24-02-27 16:34:39 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
24-02-27 16:35:23 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-27 16:35:23 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-27 16:35:23 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-27 16:35:23 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-27 16:35:23 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-27 16:35:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-27 16:35:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-27 16:35:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-27 16:35:23 WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd is not correctly working (more-info: https://www.home-assistant.io/more-info/unsupported/systemd)
24-02-27 16:35:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 16:35:23 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-27 16:35:23 INFO (MainThread) [__main__] Running Supervisor
24-02-27 16:35:23 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
24-02-27 16:35:24 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-27 16:35:24 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-27 16:35:25 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-27 16:35:25 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-27 16:35:25 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-27 16:35:25 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-27 16:35:26 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-27 16:35:26 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-27 16:35:26 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-27 16:35:26 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.2.4
24-02-27 16:35:26 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.2.4.
24-02-27 16:35:26 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-27 16:35:26 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-27 16:35:26 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-27 16:35:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-27 16:35:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-27 16:35:26 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-27 16:35:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-27 16:35:29 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-27 16:35:29 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-27 16:35:30 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-27 16:35:30 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-27 16:35:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 16:35:33 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-27 16:35:33 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-27 16:38:37 WARNING (MainThread) [supervisor.misc.tasks] Watchdog/Application found a problem with observer plugin!
24-02-27 16:38:37 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_observer application
24-02-27 16:46:00 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_observer application
s6-rc: info: service legacy-services: stopping
[16:54:43] INFO: Using udev information from host
[16:54:44] INFO: Starting local supervisor watchdog...
24-02-27 16:55:11 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-27 16:55:12 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi3-64
24-02-27 16:55:12 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.02.0
24-02-27 16:55:13 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-27 16:55:13 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 16:55:13 INFO (MainThread) [__main__] Setting up Supervisor
24-02-27 16:55:13 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-27 16:55:14 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-27 16:55:14 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-27 16:55:15 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-27 16:55:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-27 16:55:15 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-27 16:55:22 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-27 16:55:23 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-27 16:55:23 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-27 16:55:23 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-27 16:55:24 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-02-27 16:55:29 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-27 16:55:29 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-27 16:56:52 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-27 16:56:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-27 16:57:21 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-27 16:57:21 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-02-27 16:58:43 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-27 16:58:43 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-27 16:58:44 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-02-27 16:58:45 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-27 16:58:46 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-27 17:00:27 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-27 17:00:27 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-27 17:00:31 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-02-27 17:01:58 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
24-02-27 17:01:58 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-27 17:02:00 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-27 17:02:00 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-02-27 17:03:55 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-02-27 17:03:55 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-27 17:03:55 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
24-02-27 17:04:29 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-27 17:04:29 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-27 17:04:31 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.0 / BootSlot A
24-02-27 17:04:31 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-02-27 17:04:59 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-27 17:04:59 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-27 17:04:59 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-02-27 17:05:00 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-27 17:05:00 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-27 17:05:06 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-27 17:05:06 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-27 17:05:06 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-27 17:05:06 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-27 17:05:06 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-27 17:05:06 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-27 17:05:06 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 17:05:06 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-27 17:05:06 INFO (MainThread) [__main__] Running Supervisor
24-02-27 17:05:42 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-27 17:05:42 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-27 17:05:46 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-27 17:05:46 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-27 17:05:46 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-27 17:05:46 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-27 17:05:47 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-27 17:05:47 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-27 17:05:47 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-27 17:05:47 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi3-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.2.4
24-02-27 17:05:47 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant with tag 2024.2.4.
24-02-27 17:05:47 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-27 17:05:47 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-27 17:05:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-27 17:05:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-27 17:05:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-27 17:05:48 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-27 17:05:48 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-27 17:05:52 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-27 17:05:52 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-27 17:05:52 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-27 17:05:52 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-27 17:05:57 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-27 17:05:57 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-27 17:05:57 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
