I´m trying to write a script to launch the Prime video app on my Firestick. I have this working for all the other apps, but not Prime. Nothing happens when I run the script.
Can anyone tell me if the command is wrong, or in the other version the package is now different?
There is a workaround actually. Try to use custom commands with Alexa Media Player within home assistant to launch amazon prime on firetv. This works %100.
Yeah, sorry, I went back and took a look at some notes I made as I was trying to do the same thing several months ago. Sorry to say I could not figure this out either.
Can you let me see any examples, if you have that running? I’ve installed the media player addon and added this script, but I’m getting data call errors.
Try creating a new Alexa routine that launches prime video on a fire tv stick, invoke that routine in your automation. i haven’t tried that but thinking it should work.
alias: Start Amazon Prime
sequence:
- service: media_player.play_media
media_content_type: custom
media_content_id: open prime video on fire tv
entity_id: media_player.berkan_s_echo_dot
mode: single
icon: mdi:television
I am giving the custom command from another Ehco Dot through HA.
I couldn’t get the “intent” version to run either, but in my case it’s a problem with AndroidTV being > Android 9.
What version of FireOS are you running on your FTV stick? If the underlying Android version is 10 or above, there seem to be a few problems with the ADB connection (or better with the commands send).
None of the com.xxx commands I’ve found work.
The Firestick won’t run custom commands or routines, I’d guess an Echo device would allow that, but we’re Google based apart from a few Firesticks.
Please enable the debugging options for AndroidTV and the ADBcommand in HA.
And while you’re at it, do you have access to the logs from the FTVS? Can you get to the sources list of your FTVS? Maybe Amazon changed the name of the app.
Either way, if it only happens with one specific app, it must be something with your setup. I do have two older FTVS, that I normally don’t use anymore, but just tested them, both react as expected to commands, including opening the PrimeVideoApp.
I found that on my Sticks with the button I can use sendevent to capture and then use that as a command. On those without, I wrote a script to press home, right twice and select
I haven’t tried ‘transplanting’ a sendevent into those without the button, though. That might be an option.
That worked very well for a while. But not any more. The look of the Prime Video app has also changed again, so I assume that the package has a new name. Any ideas?
Edit: Found it out for myself. The new command is:
am start
com.amazon.firebat/com.amazon.firebatcore.deeplink.DeepLinkRoutingActivity
