Do you know if the MQTT works with any robot that is using the robotic-mower connect?
I’m thinking about adquiring a Anova RC500, and it uses the app
Great integration ! I “created” my Adano account in the app, logging in with my gmail account. Is there any way to login to the integration using my gmail account as well? Or do i have to create a “real” Adano account to get the integration to work?
/Rathje
Is’t possible to connect Sunseeker X5?
I just released an early beta version trying to implement the X3, X5 and X7 mowers.
I don’t have access to a mower so I’m depending on your feedback
Please report back in github
Cannot test at the moment…HACS shows an error.
Will install and try it manually the next days and report back.
Btw: Thanks for your effort!
I was now able to install via HACS and it works as a charm with the Orion X3! Thank you very much!
I downloaded the new version. Used the “new” model in the dropdown but it is not working for me. I have the X7. Using the new sunseeker app.
Let me know if i can provide anything that will help you out. I appreciate all the work your doing on this.
Are you using version 1.0.61. you should have a region dropdown too.
If it’s still not working create an issue in the GitHub repository with debug log
Hi!
I upgraded from version 1.0.20 to 1.0.63 and i have two movers.
One Meec (Jula) RMA301M20V and one Meec RMA801M20V.
After upgrade all sensors and data from them seems to work ok,
but sending commands like start robot does not work anymore.
Yes, i saw the warning
but gave i a try, think i have to downgrade or restore backup.
Thank you for nice work!
Thanks for testing @smurfen
I have just released 1.0.64 with a fix
Thanks! That was fast!
I upgraded and tested now, commands is working now, but now the sensors does not work anymore. No status, either the robot is moving or going home status is still “standby”.
Update @Sdahl1234 Upgraded HA to 2025.7 and patched the operating system, full shutdown/boot and now i can see sensor data also, all good! nice work thanks again!
I have a wish, and contacted Sunseeker on email but they did not respond.
A feature to have the mower to back more before turn around 180 degrees when edge-cutting command is sendt or enabled.
Why? Because i have built garages with 3 walls + automatic door, when edge cutting is enabled the mower try to turn around on the base station, result is that it get´s stuck in the garage.
I guess that is something that has to be done in firmware and in the API to achieve.
Would be nice to could use the edge cutting feature, but i don´t want to skip the garages with controlled ventilation, camera ++
@WhiteTigerDK
Did you get the Grouw Smart Vision 600 to work with my integration?
Extra question: Does the robot mow randomly or in straight lines?
Quick check - is the adano GitHub repo still in development? It seems abandoned compared to the sunseeker repo
It’s not abandoned.
The sunseeker has now support for the newer wireless version using another app.
If changes are made to the sunseeker integration that has something to do with the “old” app, it’s going into the adano repo as well.
Ok, so any bug fixes should be checked against the sunseeker repo, and then they’ll be downstreamed to the Adano repo?
If you find a bug in Adano, just report it in the adano repo.
I did, but there was no response. Anyway, a quick glance suggests the sunseeker might have the same, I’ll submit PRs for both
I have the same question, did you manage to use gmail login eventually? Thanks
Thanks a lot
I can confirm that Sunseeker c500 is working perfectly (old model in configuration)
