Lay-Z-Spa Hot Tub wi-fi pump automation
Just took delivery of a Laz-y-spa Toronto but the bestway app wouldn’t connect kept giving a ‘distribution network’ error so gave up and installed the Laz-y-spa app - so couldn’t use @cdpuk HACS addon, Does anyone know if the @BruceH5200 code still works?
@iamgrog68 I also just got a Toronto and have the same issue - it seems the Toronto comes with the AirJet V02, but the Bestway app only supports V01.
I’d love to hear if anyone has found a solution for this!
As an App, i binned the lazy spa and bestway smart hub app, and installed the Bestway SmartSpa app, works better than other two but still not found a solution for Home Assistant and I don’t have the brain power to figure out how to sort it.
@AaronT, @iamgrog68 - has any of you tried the Tuya SmartLife app? I am not 100% sure, but it is likely that BestWay is using the Tuya platform. (Like the other manufacturer does, as I remember…)
Same problem here, installed my new Toronto Ultrafit yesterday and only the Bestway Smartspa app worked so cant use the HACS addon.
Edit: Here is a issue about this not looking to hopeful SmartSpa by Bestway support · Issue #84 · cdpuk/ha-bestway · GitHub
Also the Bestway Smartspa app seams to be really buggy, works to control the spa manually, but no timers I have tried to setup for starting the heating during the night when power charge is cheaper has started the heater.
been ages since i installed any app on my phone and then load this to HA, but at the time i do remember having the same problem and within this thread or another very similar thread there was a note about depending what country you were in matter to what app to use, sorry was along time ago hope it helps
Just got mine, setup the lay-z-spa app which works well, but doesn’t seem to support HA
I have two timers set up in the app, heating overnight (00:01 to 5:15am) and then filter for an hour around midday and both work
