LCD PCF8574 stops working after power cycle
Hello everybody,
I have a 1602 LCD with PCF8574 connected to a nodemcu v3 (lolin).
When i run the yaml config everything works ok, i can see the information i want on the LCD but after a power cycle the LCD only shows black boxes on the first line.
I had to add a restart switch (switch: - platform: restart) and after i press it the LCD start showing the correct information.
Anybody know what is the cause and how to solve it?
I’m not going to be able to help because I’ve never used the LCD component, but neither is anyone else without seeing your config.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxx"
  password: "xxxxxxxx"
  ap:
    ssid: "Bloc Fallback Hotspot"
    password: "b7iMi656DJFZ"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
#switch:
# - platform: gpio
#   name: "comutator"
#   pin: 5
# Example configuration entry
i2c:
  sda: D4
  scl: D3
display:
  - platform: lcd_pcf8574
    dimensions: 16x2
    address: 0x27
    lambda: |-
      it.printf(0, 0, "Temp: %.1fc", id(temp).state);
      it.printf(0, 1, "Hum : %.1f  ", id(hum).state);
      it.printf(12, 0, "%.1f", id(temp_dorita));
  - platform: dht
    pin: D2
    model: DHT22
    temperature:
      on_value:
        then:
          - if:
              condition:
                lambda: 'return id(temp).state < id(temp_dorita);'
              then:
                - output.turn_on: gpio_d7
              else:
                - output.turn_off: gpio_d7
    humidity:
    update_interval: 60s
switch:
  - platform: restart
    turn_on_action:
      - switch.template.publish:
          state: ON
      - lambda: |-
          id(mydisplay).backlight();
    turn_off_action:
          state: OFF
      - lambda: |-
          id(mydisplay).no_backlight();
globals:
  - id: temp_dorita
    type: float
    initial_value: '19'
binary_sensor:
  - platform: gpio
    pin:
      number: D5
      mode: INPUT_PULLUP
    name: "creste temperatura"
    on_press:
      then:
        - lambda: 'id(temp_dorita) += 0.5;'
  - platform: gpio
    pin:
      number: D6
      mode: INPUT_PULLUP
    name: "scade temperatura"
    on_press:
      then:
        - lambda: 'id(temp_dorita) -= 0.5;'
output:
  - platform: gpio
    pin:
      number: D7
      inverted: True
