LCN light switch on Doesn’t work, only switch off
Hi, maybe someone here can help me:
I have HA running via an LCN-Visu (as well as Domiq, openHAB on Visu also works) and LCN is from about 2009. The connection to HA also works. After I have set up a simple light switch as an entity / module output, the ON/OFF status is also displayed correctly in HA when I switch directly on the switch. I can also switch the light off via HA, but not switch it on via HA. The light is also dimmable, I have tried different constellations / entities, but it does not work. If I enter entity dimmable, 100% light is only ever displayed as 25% and can be switched off but not switched on. Any idea what I can try? Thanks in advance!
Hi @ca1000,
you need to change the dimming steps. Old modules only support 50 steps. I guess you configured your system having 200 steps.
Go to Settings → Devices & Services → LCN. Click on the three vertical dots on the right side of your integration entry and select „Reconfigure“. In the dialog click on „STEPS50“ and confirm with Ok.
Andre
Thank you very much for your help, now it works!! Very much appreciated!
