LD2412 causing ESP32-s3 to reboot every 2-10 min
Hi everyone!
I’ve purchased a HLK-LD2412 (https://es.aliexpress.com/item/1005007588627535.html)
to update the ld2410 I had working on a ESP32-S3
The problem is that since I updated the code and hardware the esp32 is constantly rebooting on random time frames.
here’s my code:
substitutions:
  e_key: !secret e_key_holoroom
  ota_pass: !secret ota_holoroom
  ap: !secret ssid_holoroom
  ap_pass: !secret ssid_pass_holoroom
  ###       Seting de Puertos            ###
  #------ uart -----#
  tx_ld2412: GPIO18 #naranjo
  rx_ld2412: GPIO17 #amarillo
  id_uart: uart_fmcw
  # ---- Out Pin ----#
  #  OP_presence: GPIO7
  ###          Light Sensor            ###
  light_sensor_pin: GPIO7
  ###           BME680                 ###
  h_name: "HR% Holo"
  h_id: h_holo
  t_name: "T° Holo"
  t_id: t_holo
  p_name: "Presión en Holo"
  p_id: p_holo
  gr_name: "Resistencia de Gas"
  gr_id: gr_holo
  iaq_name: "Calidad del Aire (Raw)"
  iaq_id: iaq_raw
  iaq_class_name: "Índice de calidad del Aire"
  bme680_update: 30s
  #------- i2c-------#
  bme680_sda: GPIO8 #amarillo
  bme680_scl: GPIO9 #verde
###          Configuración             ###
esphome:
  friendly_name: Holograma's
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  flash_size: 16MB
  framework:
    type: esp-idf
    version: recommended
  variant: esp32s3
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: $e_key
ota:
  - platform: esphome
    password: $ota_pass
wifi:
  networks:
    - ssid: !secret wifi_5g
      password: !secret wifi_5g_pass
    - ssid: !secret wifi_ssid
  on_connect:
    then:
      - light.turn_on:
          brightness: 100%
          red: 0
          green: 100%
          blue: 0
      - delay: 500ms
      - light.turn_off: onboard_light
      - light.turn_on:
          brightness: 100%
          red: 0
          green: 100%
          blue: 0
      - delay: 500ms
      - light.turn_on:
          brightness: 100%
          red: 0
          green: 100%
          blue: 0
      - delay: 500ms
  on_disconnect:
    then:
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0
          blue: 0
      - delay: 500ms
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0
          blue: 0
      - delay: 500ms
      - light.turn_on:
          brightness: 100%
          red: 100%
          green: 0
          blue: 0
      - delay: 500ms
  ap:
    ssid: $ap
    password: $ap_pass
captive_portal:
i2c:
  - id: bus_a
    sda: $bme680_sda
    scl: $bme680_scl
    scan: true
uart:
  tx_pin: $rx_ld2412
  rx_pin: $tx_ld2412
  baud_rate: 115200
  parity: NONE
  stop_bits: 1
###       Sensores                     ###
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO48
    num_leds: 1
    chipset: ws2812
    restore_mode: RESTORE_DEFAULT_OFF
ld2412:
  uart_id: $id_uart
select:
  - platform: ld2412
    distance_resolution:
      name: Distance Resolution
    baud_rate:
    light_function:
number:
  - platform: ld2412
    timeout:
    min_distance_gate:
      name: Min Dist Gate
    max_distance_gate:
      name: Max Dist Gate
    light_threshold:
      name: Light Threshold
    gate_0:
      move_threshold:
        name: Gate 0 MT
      still_threshold:
        name: Gate 0 ST
    gate_1:
      move_threshold:
        name: Gate 1 MT
      still_threshold:
        name: Gate 1 ST
    gate_2:
      move_threshold:
        name: Gate 2 MT
      still_threshold:
        name: Gate 2 ST
    gate_3:
      move_threshold:
        name: Gate 3 MT
      still_threshold:
        name: Gate 3 ST
    gate_4:
      move_threshold:
        name: Gate 4 MT
      still_threshold:
        name: Gate 4 ST
    gate_5:
      move_threshold:
        name: Gate 5 MT
      still_threshold:
        name: Gate 5 ST
    gate_6:
      move_threshold:
        name: Gate 6 MT
      still_threshold:
        name: Gate 6 ST
    gate_7:
      move_threshold:
        name: Gate 7 MT
      still_threshold:
        name: Gate 7 ST
    gate_8:
      move_threshold:
        name: Gate 8 MT
      still_threshold:
        name: Gate 8 ST
    gate_9:
      move_threshold:
        name: Gate 9 MT
      still_threshold:
        name: Gate 9 ST
    gate_10:
      move_threshold:
        name: Gate 10 MT
      still_threshold:
        name: Gate 10 ST
    gate_11:
      move_threshold:
        name: Gate 11 MT
      still_threshold:
        name: Gate 11 ST
    gate_12:
      move_threshold:
        name: Gate 12 MT
      still_threshold:
        name: Gate 12 ST
    gate_13:
      move_threshold:
        name: Gate 13 MT
      still_threshold:
        name: Gate 13 ST
text_sensor:
  - platform: ld2412
    version:
      name: ld2412 Firmware version
    mac_address:
      name: ld2412 Mac Address
  # Sensor THPG Pieza
  # Sin BSEC
    icon: "mdi:checkbox-marked-circle-outline"
    lambda: |-
      if ( int(id($iaq_id).state) <= 50) {
        return {"Excelente"};
      else if (int(id($iaq_id).state) >= 51 && int(id($iaq_id).state) <= 100) {
        return {"Bueno"};
      else if (int(id($iaq_id).state) >= 101 && int(id($iaq_id).state) <= 150) {
        return {"Ligeramente contaminado"};
      else if (int(id($iaq_id).state) >= 151 && int(id($iaq_id).state) <= 200) {
        return {"Moderadamente contaminado"};
      else if (int(id($iaq_id).state) >= 201 && int(id($iaq_id).state) <= 250) {
        return {"Altamente contaminado"};
      else if (int(id($iaq_id).state) >= 251 && int(id($iaq_id).state) <= 350) {
        return {"Gravemente contaminado"};
      else if (int(id($iaq_id).state) >= 351) {
        return {"Extremadamente contaminado"};
      else {
        return {"Error"};
switch:
  - platform: ld2412
    engineering_mode:
    bluetooth:
      restore_mode: ALWAYS_OFF
  #Señal de wi-fi
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "Señal WiFi HoloRoom (dB)"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: holo_wifi
    name: "WiFi Holograma's Room"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Señal %"
  - platform: adc
    name: "Luz en HoloRoom (V)"
    pin: $light_sensor_pin
    attenuation: 12db
    update_interval: 1s
    unit_of_measurement: "V"
    filters:
      - median:
          window_size: 5
          send_every: 2
  # Lux calibrado EXACTO para tu módulo GL5528+LM358+10kΩ
    name: "Luz HoloRoom GL5528 (lux)"
    unit_of_measurement: "lx"
    accuracy_decimals: 0
    icon: "mdi:lightbulb-outline"
    update_interval: 5s
    lambda: |-
      const float Vout = id(lux_voltage).state;
      if (Vout < 0.05f) return 0.0f;  // Oscuridad
      const float VCC = 3.3f;
      const float R1 = 10000.0f;      // Del esquema PDF
      const float R10lux = 15000.0f;  // GL5528 @10lux
      const float gamma = 0.6f;       // GL5528 datasheet
      // Física exacta del circuito
      float R_LDR = R1 * (VCC / Vout - 1.0f);
      if (R_LDR > 1000000.0f) R_LDR = 1000000.0f;  // Saturación oscuridad
      // Modelo GL5528: lux = 10 * (R10/R)^(1/γ)
      float lux_fisico = 10.0f * powf(R10lux / R_LDR, 1.0f / gamma);
      // Corrección calibrada con TUS 7 puntos (m=0.84, c=1.007)
      float log10_lux = 0.84f * log10f(lux_fisico) + 1.007f;
      float lux = powf(10.0f, log10_lux);
      if (lux > 10000.0f) lux = 10000.0f;
      return roundf(lux);
  # Sensor THPG Pieza
  #Sin BSEC
  - platform: bme680
    temperature:
    pressure:
    humidity:
    gas_resistance:
    address: 0x77
    update_interval: $bme680_update
    icon: "mdi:gauge"
    # calculation: comp_gas = log(R_gas[ohm]) + 0.04 log(Ohm)/%rh * hum[%rh]
    lambda: |-
      return log(id($gr_id).state) + 0.04 * id($h_id).state;
    state_class: "measurement"
  #sensores de mov
  - platform: ld2412
    moving_distance:
    still_distance:
    moving_energy:
    still_energy:
    detection_distance:
    gate_0:
      move_energy:
      still_energy:
    gate_1:
      move_energy:
      still_energy:
    gate_2:
      move_energy:
      still_energy:
    gate_3:
      move_energy:
      still_energy:
    gate_4:
      move_energy:
      still_energy:
    gate_5:
      move_energy:
      still_energy:
    gate_6:
      move_energy:
      still_energy:
    gate_7:
      move_energy:
      still_energy:
    gate_8:
      move_energy:
      still_energy:
    gate_9:
      move_energy:
      still_energy:
    gate_10:
      move_energy:
      still_energy:
    gate_11:
      move_energy:
      still_energy:
    gate_12:
      move_energy:
      still_energy:
    gate_13:
      move_energy:
      still_energy:
    light:
binary_sensor:
  - platform: status
  - platform: ld2412
    has_target:
    has_moving_target:
      name: Pres Movimiento
    has_still_target:
    dynamic_background_correction_status:
      name: Dynamic Background Correction Status
    # out_pin_presence_status:
    #   name: OP Presence
  # - platform: gpio
  #   pin: $OP_presence
  #   name: gpio out presence
  #   device_class: presence
button:
  - platform: restart
  - platform: ld2412
    factory_reset:
      name: ld2412 Factory Reset
    restart:
    query_params:
      name: ld2412 Query Params
    start_dynamic_background_correction:
      name: ld2412 Start Dynamic Background Correction
Any idea on what may cause this? or tips on how to debug?
Is your “Configuración” section still accurate?
Turn on debug in your ESPHome code, purge your ESPHome cache, recompile, and post your compile and running log here.
[Note that once you purge your ESPHome cache, it will download fresh new code over the internet and recompile it, so the first compile pass after you purge will take a very long time. Expect it and don’t panic.]
This is the log file
INFO ESPHome 2025.12.2
INFO Reading configuration /config/esphome/hologramas.yaml...
INFO Starting log output from 192.168.100.80 using esphome API
INFO Successfully resolved hologramas @ 192.168.100.80 in 0.000s
WARNING Can't connect to ESPHome API for hologramas @ 192.168.100.80: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.100.80', port=6053))] (TimeoutAPIError)
INFO Trying to connect to hologramas @ 192.168.100.80 in the background
INFO Successfully connected to hologramas @ 192.168.100.80 in 0.032s
INFO Successful handshake with hologramas @ 192.168.100.80 in 0.099s
[20:34:43.328][I][app:194]: ESPHome version 2025.12.2 compiled on Dec 27 2025, 05:56:19
[20:34:43.329][C][logger:261]: Logger:
[20:34:43.329][C][logger:261]:   Max Level: DEBUG
[20:34:43.329][C][logger:261]:   Initial Level: DEBUG
[20:34:43.335][C][logger:267]:   Log Baud Rate: 115200
[20:34:43.335][C][logger:267]:   Hardware UART: USB_SERIAL_JTAG
[20:34:43.336][C][logger:274]:   Task Log Buffer Size: 768
[20:34:43.343][C][i2c.idf:090]: I2C Bus:
[20:34:43.345][C][i2c.idf:091]:   SDA Pin: GPIO8
[20:34:43.345][C][i2c.idf:091]:   SCL Pin: GPIO9
[20:34:43.345][C][i2c.idf:091]:   Frequency: 50000 Hz
[20:34:43.348][C][i2c.idf:101]:   Recovery: bus successfully recovered
[20:34:43.357][C][i2c.idf:111]: Results from bus scan:
[20:34:43.358][C][i2c.idf:117]: Found device at address 0x77
[20:34:43.360][C][uart.idf:238]: UART Bus 0:
[20:34:43.365][C][uart.idf:239]:   TX Pin: GPIO17
[20:34:43.365][C][uart.idf:240]:   RX Pin: GPIO18
[20:34:43.366][C][uart.idf:243]:   RX Buffer Size: 256
[20:34:43.366][C][uart.idf:243]:   RX Full Threshold: 114
[20:34:43.366][C][uart.idf:243]:   RX Timeout: 2
[20:34:43.377][C][uart.idf:249]:   Baud Rate: 115200 baud
[20:34:43.377][C][uart.idf:249]:   Data Bits: 8
[20:34:43.377][C][uart.idf:249]:   Parity: NONE
[20:34:43.377][C][uart.idf:249]:   Stop bits: 1
[20:34:43.391][C][esp32_rmt_led_strip:268]: ESP32 RMT LED Strip:
[20:34:43.391][C][esp32_rmt_led_strip:268]:   Pin: 48
[20:34:43.406][C][esp32_rmt_led_strip:272]:   RMT Symbols: 192
[20:34:43.406][C][esp32_rmt_led_strip:297]:   RGB Order: GRB
[20:34:43.406][C][esp32_rmt_led_strip:297]:   Max refresh rate: 0
[20:34:43.406][C][esp32_rmt_led_strip:297]:   Number of LEDs: 1
[20:34:43.411][C][template.text_sensor:016]: Template Sensor 'Índice de calidad del Aire'
[20:34:43.412][C][template.text_sensor:023]:   Icon: 'mdi:checkbox-marked-circle-outline'
[20:34:43.422][C][template.sensor:017]: Template Sensor 'Luz HoloRoom GL5528 (lux)'
[20:34:43.422][C][template.sensor:017]:   State Class: ''
[20:34:43.422][C][template.sensor:017]:   Unit of Measurement: 'lx'
[20:34:43.422][C][template.sensor:017]:   Accuracy Decimals: 0
[20:34:43.433][C][template.sensor:031]:   Icon: 'mdi:lightbulb-outline'
[20:34:43.434][C][template.sensor:399]:   Update Interval: 5.0s
[20:34:43.434][C][template.sensor:017]: Template Sensor 'Calidad del Aire (Raw)'
[20:34:43.434][C][template.sensor:017]:   State Class: 'measurement'
[20:34:43.434][C][template.sensor:017]:   Unit of Measurement: ''
[20:34:43.434][C][template.sensor:017]:   Accuracy Decimals: 1
[20:34:43.434][C][template.sensor:031]:   Icon: 'mdi:gauge'
[20:34:43.436][C][template.sensor:399]:   Update Interval: 60.0s
[20:34:43.610][D][light:090]: 'LED Onboard' Setting:
[20:34:43.616][D][light:103]:   State: OFF
[20:34:43.616][D][light:141]:   Transition length: 1.0s
[20:34:43.791][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.24000 V with 2 decimals of accuracy
[20:34:43.840][C][light:091]: Light 'LED Onboard'
[20:34:43.841][C][light:094]:   Default Transition Length: 1.0s
[20:34:43.841][C][light:094]:   Gamma Correct: 2.80
[20:34:43.847][C][psram:016]: PSRAM:
[20:34:43.865][C][psram:019]:   Available: YES
[20:34:43.865][C][psram:021]:   Size: 8192 KB
[20:34:43.866][C][ld2412:204]: LD2412:
[20:34:43.866][C][ld2412:204]:   Firmware version: 0.00.00000000
[20:34:43.866][C][ld2412:204]:   MAC address: unknown
[20:34:43.866][C][ld2412:210]: Binary Sensors:
[20:34:43.866][C][ld2412:016]:   DynamicBackgroundCorrectionStatus 'Dynamic Background Correction Status'
[20:34:43.867][C][ld2412:019]:     Device Class: 'running'
[20:34:43.870][C][ld2412:016]:   MovingTarget 'Pres Movimiento'
[20:34:43.877][C][ld2412:019]:     Device Class: 'motion'
[20:34:43.881][C][ld2412:016]:   StillTarget 'Obj. Quieto'
[20:34:43.887][C][ld2412:019]:     Device Class: 'occupancy'
[20:34:43.888][C][ld2412:016]:   Target 'Presencia'
[20:34:43.889][C][ld2412:019]:     Device Class: 'occupancy'
[20:34:43.893][C][ld2412:218]: Sensors:
[20:34:43.902][C][ld2412:017]:   Light 'luz'
[20:34:43.902][C][ld2412:017]:     State Class: ''
[20:34:43.902][C][ld2412:017]:     Unit of Measurement: ''
[20:34:43.902][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.903][C][ld2412:027]:     Device Class: 'illuminance'
[20:34:43.903][C][ld2412:031]:     Icon: 'mdi:lightbulb'
[20:34:43.904][C][ld2412:017]:   DetectionDistance 'Detección (cm)'
[20:34:43.904][C][ld2412:017]:     State Class: ''
[20:34:43.904][C][ld2412:017]:     Unit of Measurement: 'cm'
[20:34:43.904][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.908][C][ld2412:027]:     Device Class: 'distance'
[20:34:43.916][C][ld2412:031]:     Icon: 'mdi:signal-distance-variant'
[20:34:43.917][C][ld2412:017]:   MovingTargetDistance 'Movimiento (cm)'
[20:34:43.917][C][ld2412:017]:     State Class: ''
[20:34:43.917][C][ld2412:017]:     Unit of Measurement: 'cm'
[20:34:43.917][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.917][C][ld2412:027]:     Device Class: 'distance'
[20:34:43.922][C][ld2412:031]:     Icon: 'mdi:signal-distance-variant'
[20:34:43.929][C][ld2412:017]:   MovingTargetEnergy 'Movimiento (%)'
[20:34:43.929][C][ld2412:017]:     State Class: ''
[20:34:43.929][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.929][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.930][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:43.930][C][ld2412:017]:   StillTargetDistance 'Quieto (cm)'
[20:34:43.930][C][ld2412:017]:     State Class: ''
[20:34:43.930][C][ld2412:017]:     Unit of Measurement: 'cm'
[20:34:43.930][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.941][C][ld2412:027]:     Device Class: 'distance'
[20:34:43.944][C][ld2412:031]:     Icon: 'mdi:signal-distance-variant'
[20:34:43.944][C][ld2412:017]:   StillTargetEnergy 'Quieto (%)'
[20:34:43.944][C][ld2412:017]:     State Class: ''
[20:34:43.944][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.944][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.945][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.946][C][ld2412:017]:   GateStill 'g0 Quieto'
[20:34:43.946][C][ld2412:017]:     State Class: ''
[20:34:43.946][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.946][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.950][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.952][C][ld2412:017]:   GateStill 'g1 Quieto'
[20:34:43.952][C][ld2412:017]:     State Class: ''
[20:34:43.952][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.952][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.961][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.963][C][ld2412:017]:   GateStill 'g2 Quieto'
[20:34:43.963][C][ld2412:017]:     State Class: ''
[20:34:43.963][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.963][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.965][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.973][C][ld2412:017]:   GateStill 'g3 Quieto'
[20:34:43.973][C][ld2412:017]:     State Class: ''
[20:34:43.973][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.973][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.974][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.974][C][ld2412:017]:   GateStill 'g4 Quieto'
[20:34:43.974][C][ld2412:017]:     State Class: ''
[20:34:43.974][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.974][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.989][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.989][C][ld2412:017]:   GateStill 'g5 Quieto'
[20:34:43.989][C][ld2412:017]:     State Class: ''
[20:34:43.989][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.989][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.990][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.990][C][ld2412:017]:   GateStill 'g6 Quieto'
[20:34:43.990][C][ld2412:017]:     State Class: ''
[20:34:43.990][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.990][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.991][C][ld2412:017]:   GateStill 'g7 Quieto'
[20:34:43.991][C][ld2412:017]:     State Class: ''
[20:34:43.991][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.991][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:43.997][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:43.999][C][ld2412:017]:   GateStill 'g8 Quieto'
[20:34:43.999][C][ld2412:017]:     State Class: ''
[20:34:43.999][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:43.999][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.004][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.010][C][ld2412:017]:   GateStill 'g9 Quieto'
[20:34:44.010][C][ld2412:017]:     State Class: ''
[20:34:44.010][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.010][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.012][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.013][C][ld2412:017]:   GateStill 'g10 Quieto'
[20:34:44.013][C][ld2412:017]:     State Class: ''
[20:34:44.013][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.013][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.022][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.023][C][ld2412:017]:   GateStill 'g11 Quieto'
[20:34:44.023][C][ld2412:017]:     State Class: ''
[20:34:44.023][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.023][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.024][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.032][C][ld2412:017]:   GateStill 'g12 Quieto'
[20:34:44.032][C][ld2412:017]:     State Class: ''
[20:34:44.032][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.032][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.045][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.046][C][ld2412:017]:   GateStill 'g13 Quieto'
[20:34:44.046][C][ld2412:017]:     State Class: ''
[20:34:44.046][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.046][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.046][C][ld2412:031]:     Icon: 'mdi:flash'
[20:34:44.046][C][ld2412:017]:   GateMove 'g0 Mov'
[20:34:44.047][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.047][C][ld2412:017]:   GateMove 'g1 Mov'
[20:34:44.047][C][ld2412:017]:     State Class: ''
[20:34:44.047][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.047][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.051][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.054][C][ld2412:017]:   GateMove 'g2 Mov'
[20:34:44.054][C][ld2412:017]:     State Class: ''
[20:34:44.054][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.054][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.070][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.070][C][ld2412:017]:   GateMove 'g3 Mov'
[20:34:44.070][C][ld2412:017]:     State Class: ''
[20:34:44.070][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.070][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.071][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.071][C][ld2412:017]:   GateMove 'g4 Mov'
[20:34:44.071][C][ld2412:017]:     State Class: ''
[20:34:44.071][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.071][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.082][C][ld2412:017]:   GateMove 'g5 Mov'
[20:34:44.082][C][ld2412:017]:     State Class: ''
[20:34:44.082][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.082][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.083][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.087][C][ld2412:017]:   GateMove 'g6 Mov'
[20:34:44.087][C][ld2412:017]:     State Class: ''
[20:34:44.087][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.087][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.094][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.094][C][ld2412:017]:   GateMove 'g7 Mov'
[20:34:44.094][C][ld2412:017]:     State Class: ''
[20:34:44.094][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.094][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.095][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.095][C][ld2412:017]:   GateMove 'g8 Mov'
[20:34:44.095][C][ld2412:017]:     State Class: ''
[20:34:44.095][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.095][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.098][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.100][C][ld2412:017]:   GateMove 'g9 Mov'
[20:34:44.100][C][ld2412:017]:     State Class: ''
[20:34:44.100][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.100][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.107][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.127][C][ld2412:017]:   GateMove 'g10 Mov'
[20:34:44.127][C][ld2412:017]:     State Class: ''
[20:34:44.127][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.127][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.128][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.128][C][ld2412:017]:   GateMove 'g11 Mov'
[20:34:44.128][C][ld2412:017]:     State Class: ''
[20:34:44.128][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.128][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.129][C][ld2412:017]:   GateMove 'g12 Mov'
[20:34:44.129][C][ld2412:017]:     State Class: ''
[20:34:44.129][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.129][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.130][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.130][C][ld2412:017]:   GateMove 'g13 Mov'
[20:34:44.130][C][ld2412:017]:     State Class: ''
[20:34:44.130][C][ld2412:017]:     Unit of Measurement: '%'
[20:34:44.130][C][ld2412:017]:     Accuracy Decimals: 0
[20:34:44.135][C][ld2412:031]:     Icon: 'mdi:motion-sensor'
[20:34:44.136][C][ld2412:233]: Text Sensors:
[20:34:44.139][C][ld2412:016]:   MAC address 'ld2412 Mac Address'
[20:34:44.148][C][ld2412:023]:     Icon: 'mdi:bluetooth'
[20:34:44.148][C][ld2412:016]:   Version 'ld2412 Firmware version'
[20:34:44.149][C][ld2412:023]:     Icon: 'mdi:chip'
[20:34:44.149][C][ld2412:238]: Numbers:
[20:34:44.159][C][ld2412:016]:   LightThreshold 'Light Threshold'
[20:34:44.160][C][ld2412:019]:     Icon: 'mdi:lightbulb'
[20:34:44.160][C][ld2412:027]:     Device Class: 'illuminance'
[20:34:44.169][C][ld2412:016]:   MaxDistanceGate 'Max Dist Gate'
[20:34:44.174][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.174][C][ld2412:027]:     Device Class: 'distance'
[20:34:44.174][C][ld2412:016]:   MinDistanceGate 'Min Dist Gate'
[20:34:44.178][C][ld2412:027]:     Device Class: 'distance'
[20:34:44.178][C][ld2412:016]:   Timeout 'Presence Timeout'
[20:34:44.184][C][ld2412:019]:     Icon: 'mdi:timelapse'
[20:34:44.197][C][ld2412:023]:     Unit of Measurement: 's'
[20:34:44.197][C][ld2412:016]:   Move Thresholds 'Gate 0 MT'
[20:34:44.197][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.197][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.197][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.197][C][ld2412:016]:   Move Thresholds 'Gate 1 MT'
[20:34:44.202][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.205][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.215][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.216][C][ld2412:016]:   Move Thresholds 'Gate 2 MT'
[20:34:44.216][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.216][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.218][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.223][C][ld2412:016]:   Move Thresholds 'Gate 3 MT'
[20:34:44.224][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.230][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.236][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.236][C][ld2412:016]:   Move Thresholds 'Gate 4 MT'
[20:34:44.252][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.253][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.253][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.253][C][ld2412:016]:   Move Thresholds 'Gate 5 MT'
[20:34:44.253][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.256][C][ld2412:016]:   Move Thresholds 'Gate 6 MT'
[20:34:44.259][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.264][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.269][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.271][C][ld2412:016]:   Move Thresholds 'Gate 7 MT'
[20:34:44.275][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.280][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.281][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.286][C][ld2412:016]:   Move Thresholds 'Gate 8 MT'
[20:34:44.291][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.291][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.291][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.298][C][ld2412:016]:   Move Thresholds 'Gate 9 MT'
[20:34:44.299][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.300][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.305][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.308][C][ld2412:016]:   Move Thresholds 'Gate 10 MT'
[20:34:44.312][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.313][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.317][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.321][C][ld2412:016]:   Move Thresholds 'Gate 11 MT'
[20:34:44.326][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.327][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.338][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.338][C][ld2412:016]:   Move Thresholds 'Gate 12 MT'
[20:34:44.338][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.339][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.339][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.354][C][ld2412:016]:   Move Thresholds 'Gate 13 MT'
[20:34:44.354][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.355][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.355][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.355][C][ld2412:016]:   Still Thresholds 'Gate 0 ST'
[20:34:44.360][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.360][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.363][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.369][C][ld2412:016]:   Still Thresholds 'Gate 1 ST'
[20:34:44.372][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.373][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.384][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.385][C][ld2412:016]:   Still Thresholds 'Gate 2 ST'
[20:34:44.385][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.403][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.403][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.404][C][ld2412:016]:   Still Thresholds 'Gate 3 ST'
[20:34:44.404][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.404][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.404][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.404][C][ld2412:016]:   Still Thresholds 'Gate 4 ST'
[20:34:44.405][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.410][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.414][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.414][C][ld2412:016]:   Still Thresholds 'Gate 5 ST'
[20:34:44.420][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.422][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.428][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.440][C][ld2412:016]:   Still Thresholds 'Gate 6 ST'
[20:34:44.441][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.441][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.441][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.441][C][ld2412:016]:   Still Thresholds 'Gate 7 ST'
[20:34:44.442][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.446][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.456][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.457][C][ld2412:016]:   Still Thresholds 'Gate 8 ST'
[20:34:44.457][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.457][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.458][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.462][C][ld2412:016]:   Still Thresholds 'Gate 9 ST'
[20:34:44.465][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.470][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.480][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.481][C][ld2412:016]:   Still Thresholds 'Gate 10 ST'
[20:34:44.481][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.481][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.485][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.505][C][ld2412:016]:   Still Thresholds 'Gate 11 ST'
[20:34:44.505][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.505][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.506][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.506][C][ld2412:016]:   Still Thresholds 'Gate 12 ST'
[20:34:44.506][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.506][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.507][C][ld2412:016]:   Still Thresholds 'Gate 13 ST'
[20:34:44.510][C][ld2412:019]:     Icon: 'mdi:motion-sensor'
[20:34:44.517][C][ld2412:023]:     Unit of Measurement: '%'
[20:34:44.517][C][ld2412:027]:     Device Class: 'signal_strength'
[20:34:44.531][C][ld2412:251]: Selects:
[20:34:44.531][C][ld2412:252]:   BaudRate 'Baud Rate'
[20:34:44.532][C][ld2412:252]:     Icon: 'mdi:thermometer'
[20:34:44.532][C][ld2412:253]:   DistanceResolution 'Distance Resolution'
[20:34:44.532][C][ld2412:253]:     Icon: 'mdi:ruler'
[20:34:44.542][C][ld2412:254]:   LightFunction 'Light Function'
[20:34:44.543][C][ld2412:254]:     Icon: 'mdi:lightbulb'
[20:34:44.543][C][ld2412:258]: Switches:
[20:34:44.543][C][ld2412:092]:   Bluetooth 'Bluetooth ld2412'
[20:34:44.543][C][ld2412:092]:     Restore Mode: always OFF
[20:34:44.543][C][ld2412:100]:     Icon: 'mdi:bluetooth'
[20:34:44.548][C][ld2412:109]:     Device Class: 'switch'
[20:34:44.556][C][ld2412:092]:   EngineeringMode 'Engineering Mode'
[20:34:44.556][C][ld2412:092]:     Restore Mode: always OFF
[20:34:44.557][C][ld2412:100]:     Icon: 'mdi:pulse'
[20:34:44.557][C][ld2412:109]:     Device Class: 'switch'
[20:34:44.558][C][ld2412:263]: Buttons:
[20:34:44.564][C][ld2412:014]:   FactoryReset 'ld2412 Factory Reset'
[20:34:44.565][C][ld2412:017]:     Icon: 'mdi:restart-alert'
[20:34:44.577][C][ld2412:014]:   Query 'ld2412 Query Params'
[20:34:44.577][C][ld2412:017]:     Icon: 'mdi:database'
[20:34:44.577][C][ld2412:014]:   Restart 'ld2412 Restart'
[20:34:44.577][C][ld2412:017]:     Icon: 'mdi:restart'
[20:34:44.586][C][ld2412:014]:   StartDynamicBackgroundCorrection 'ld2412 Start Dynamic Background Correction'
[20:34:44.587][C][ld2412:017]:     Icon: 'mdi:pulse'
[20:34:44.606][C][copy.sensor:017]: Copy Sensor 'WiFi Holograma's Room'
[20:34:44.606][C][copy.sensor:017]:   State Class: 'measurement'
[20:34:44.606][C][copy.sensor:017]:   Unit of Measurement: 'Señal %'
[20:34:44.606][C][copy.sensor:017]:   Accuracy Decimals: 0
[20:34:44.607][C][copy.sensor:027]:   Device Class: 'signal_strength'
[20:34:44.607][D][api:136]: Accept 192.168.100.222
[20:34:44.607][C][adc.esp32:017]: ADC Sensor 'Luz en HoloRoom (V)'
[20:34:44.607][C][adc.esp32:017]:   State Class: 'measurement'
[20:34:44.607][C][adc.esp32:017]:   Unit of Measurement: 'V'
[20:34:44.607][C][adc.esp32:017]:   Accuracy Decimals: 2
[20:34:44.608][C][adc.esp32:027]:   Device Class: 'voltage'
[20:34:44.608][C][adc.esp32:123]:   Pin: GPIO7
[20:34:44.612][C][adc.esp32:124]:   Channel:       6
[20:34:44.612][C][adc.esp32:124]:   Unit:          ADC1
[20:34:44.612][C][adc.esp32:124]:   Attenuation:   12 dB
[20:34:44.612][C][adc.esp32:124]:   Samples:       1
[20:34:44.612][C][adc.esp32:124]:   Sampling mode: average
[20:34:44.619][C][adc.esp32:134]:   Setup Status:
[20:34:44.619][C][adc.esp32:134]:     Handle Init:  OK
[20:34:44.619][C][adc.esp32:134]:     Config:       OK
[20:34:44.619][C][adc.esp32:134]:     Calibration:  OK
[20:34:44.619][C][adc.esp32:134]:     Overall Init: OK
[20:34:44.620][C][adc.esp32:399]:   Update Interval: 1.0s
[20:34:44.668][C][bme680.sensor:214]: BME680:
[20:34:44.669][C][bme680.sensor:215]:   Address: 0x77
[20:34:44.674][C][bme680.sensor:219]:   IIR Filter: OFF
[20:34:44.678][C][bme680.sensor:399]:   Update Interval: 30.0s
[20:34:44.686][C][bme680.sensor:017]:   Temperature 'T° Holo'
[20:34:44.686][C][bme680.sensor:017]:     State Class: 'measurement'
[20:34:44.686][C][bme680.sensor:017]:     Unit of Measurement: '°C'
[20:34:44.686][C][bme680.sensor:017]:     Accuracy Decimals: 1
[20:34:44.686][C][bme680.sensor:027]:     Device Class: 'temperature'
[20:34:44.700][C][bme680.sensor:223]:     Oversampling: 16x
[20:34:44.701][C][bme680.sensor:017]:   Pressure 'Presión en Holo'
[20:34:44.701][C][bme680.sensor:017]:     State Class: 'measurement'
[20:34:44.701][C][bme680.sensor:017]:     Unit of Measurement: 'hPa'
[20:34:44.701][C][bme680.sensor:017]:     Accuracy Decimals: 1
[20:34:44.701][C][bme680.sensor:027]:     Device Class: 'atmospheric_pressure'
[20:34:44.702][C][bme680.sensor:225]:     Oversampling: 16x
[20:34:44.702][C][bme680.sensor:017]:   Humidity 'HR% Holo'
[20:34:44.702][C][bme680.sensor:017]:     State Class: 'measurement'
[20:34:44.702][C][bme680.sensor:017]:     Unit of Measurement: '%'
[20:34:44.702][C][bme680.sensor:017]:     Accuracy Decimals: 1
[20:34:44.708][C][bme680.sensor:027]:     Device Class: 'humidity'
[20:34:44.709][C][bme680.sensor:227]:     Oversampling: 16x
[20:34:44.709][C][bme680.sensor:017]:   Gas Resistance 'Resistencia de Gas'
[20:34:44.709][C][bme680.sensor:017]:     State Class: 'measurement'
[20:34:44.709][C][bme680.sensor:017]:     Unit of Measurement: 'Ω'
[20:34:44.709][C][bme680.sensor:017]:     Accuracy Decimals: 1
[20:34:44.722][C][bme680.sensor:031]:     Icon: 'mdi:gas-cylinder'
[20:34:44.748][C][bme680.sensor:232]:   Heater temperature=320°C duration=150ms
[20:34:44.748][C][status:016]: Status Binary Sensor 'Estado'
[20:34:44.748][C][status:019]:   Device Class: 'connectivity'
[20:34:44.756][D][api.connection:1398]: Home Assistant 2025.12.4 (192.168.100.222) connected
[20:34:44.765][C][restart.button:014]: Restart Button 'Restart'
[20:34:44.766][C][restart.button:017]:   Icon: 'mdi:restart'
[20:34:44.766][C][captive_portal:118]: Captive Portal:
[20:34:44.776][C][wifi:1132]: WiFi:
[20:34:44.776][C][wifi:1132]:   Connected: YES
[20:34:44.782][C][wifi:897]:   Local MAC: 24:58:7C:E1:F9:B8
[20:34:44.782][C][wifi:904]:   IP Address: 192.168.100.80
[20:34:44.793][C][wifi:908]:   SSID:
[20:34:44.793][C][wifi:908]:   BSSID:
[20:34:44.793][C][wifi:908]:   Hostname: 'hologramas'
[20:34:44.793][C][wifi:908]:   Signal strength: -45 dB ▂▄▆█
[20:34:44.793][C][wifi:908]:   Channel: 6
[20:34:44.793][C][wifi:908]:   Subnet: 255.255.255.0
[20:34:44.793][C][wifi:908]:   Gateway: 192.168.100.1
[20:34:44.793][C][wifi:908]:   DNS1: 192.168.100.1
[20:34:44.793][C][wifi:908]:   DNS2: 0.0.0.0
[20:34:44.794][C][esphome.ota:092]: Over-The-Air updates:
[20:34:44.794][C][esphome.ota:092]:   Address: hologramas.local:3232
[20:34:44.794][C][esphome.ota:092]:   Version: 2
[20:34:44.795][C][esphome.ota:099]:   Password configured
[20:34:44.814][C][safe_mode:018]: Safe Mode:
[20:34:44.814][C][safe_mode:018]:   Successful after: 60s
[20:34:44.814][C][safe_mode:018]:   Invoke after: 10 attempts
[20:34:44.814][C][safe_mode:018]:   Duration: 300s
[20:34:44.814][W][safe_mode:030]: Last reset too quick; invoke in 8 restarts
[20:34:44.815][C][web_server.ota:241]: Web Server OTA
[20:34:44.839][C][api:211]: Server:
[20:34:44.839][C][api:211]:   Address: hologramas.local:6053
[20:34:44.839][C][api:211]:   Listen backlog: 4
[20:34:44.839][C][api:211]:   Max connections: 8
[20:34:44.840][C][api:218]:   Noise encryption: YES
[20:34:44.850][C][wifi_signal.sensor:017]: WiFi Signal 'Señal WiFi HoloRoom (dB)'
[20:34:44.850][C][wifi_signal.sensor:017]:   State Class: 'measurement'
[20:34:44.850][C][wifi_signal.sensor:017]:   Unit of Measurement: 'dBm'
[20:34:44.850][C][wifi_signal.sensor:017]:   Accuracy Decimals: 0
[20:34:44.850][C][wifi_signal.sensor:027]:   Device Class: 'signal_strength'
[20:34:44.867][C][mdns:177]: mDNS:
[20:34:44.867][C][mdns:177]:   Hostname: hologramas
[20:34:45.482][D][sensor:135]: 'Luz HoloRoom GL5528 (lux)': Sending state 4.00000 lx with 0 decimals of accuracy
[20:34:45.794][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.24200 V with 2 decimals of accuracy
[20:34:47.881][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.23600 V with 2 decimals of accuracy
[20:34:49.800][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.23500 V with 2 decimals of accuracy
[20:34:50.566][D][sensor:135]: 'Luz HoloRoom GL5528 (lux)': Sending state 3.00000 lx with 0 decimals of accuracy
[20:34:51.633][D][binary_sensor:047]: 'Presencia': ON
[20:34:51.633][D][binary_sensor:047]: 'Pres Movimiento': ON
[20:34:51.633][D][binary_sensor:047]: 'Obj. Quieto': ON
[20:34:51.633][D][sensor:135]: 'Movimiento (cm)': Sending state 831.00000 cm with 0 decimals of accuracy
[20:34:51.633][D][sensor:135]: 'Movimiento (%)': Sending state 100.00000 % with 0 decimals of accuracy
[20:34:51.634][D][sensor:135]: 'Detección (cm)': Sending state 831.00000 cm with 0 decimals of accuracy
[20:34:51.805][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.19600 V with 2 decimals of accuracy
[20:34:52.679][D][sensor:135]: 'Movimiento (cm)': Sending state 147.00000 cm with 0 decimals of accuracy
[20:34:52.693][D][sensor:135]: 'Movimiento (%)': Sending state 50.00000 % with 0 decimals of accuracy
[20:34:52.694][D][sensor:135]: 'Detección (cm)': Sending state 147.00000 cm with 0 decimals of accuracy
[20:34:53.822][D][sensor:135]: 'Luz en HoloRoom (V)': Sending state 0.22800 V with 2 decimals of accuracy...
I encountered a similar issue with an LD2410. I solved it by wiring it to 3.3 V instead of 5 V. It might work for your LD2412, too.
Thank you, but is already powered by 3.3v pin
I found the problem. It was a very “noob one”. The issue was indeed the power. I had it connected to a usb charger with 2A but I was using a usb extender that clearly was not able to draw sufficient power. I changed to a buck converter with good wiring and 0.6A and it has been working properly since.
