LED colour status - save my sanity!
Beyond joking and sweating, these sensors (speed of sound) are noticeably affected by heat. With careful mount to fixed distance you could use it as thermometer. :slightly_smiling_face:
I definitely see a shelf in the graph when the coffee machine turns on…but given the measurement interval at that point is 10 seconds, I’d have expected to see a slope or a curve.
The 20us pulse has definitely improved things. At first it was 100% successful…but it’s like proving something doesn’t happen. I do get some logs that it has failed to start measurement. I’m currently fiddling with timeout to see if that improves things. I know this sensor has a significant (at these timescales) delay before the result is returned. With the ā€œtimeout: 8mā€ it brings the timeout to 46647 µs as reported in the logs. That should be longer than the 42ms I’d measured with an oscilloscope so we’ll see if that helps or if I’m barking up the wrong tree! It does specifically log that it fails to START measurement but it’s always possible it’s a collision with the previous result or mis-logged or something. Worth a shot anyway. So far it’s logging all good…but as I say, it’s waiting for something to not happen :smiley:
