How do you came for -0.02 constant please?
I used:
hs_color: ['{{(states("sensor.co2") | float - 400) * 0.15 }}','100']
and it works. There are problem with the return of more than one values.
I used:
I generated a linear equation (y = mx + b ) to convert 12000-0 to 236-0.
-0.02 is the slope of the line not the constant.
A template can only return a string, not a YAML array. (I wonder how many times Iāve written that in replies in this forum⦠) So you have to make sure youāre not trying to render both
hs_color
values in a single template. If you change the hs_color
part to the following it should work. (BTW, no comment on what the equation should be. You and @tom_l have that covered.)
hs_color:
{% set co2 = states('sensor.co2') %}
{% if co2 == 'unavailable' %}
360
{% elif co2 | float < 2000 %}
{{ ((co2 | float - 400) * 0.15) | round(0) | int }}
{% else %}
1
{% endif %}
- 100
Thanks! I found that a couple minutes ago. Will try.
Is there anyone with a ESPhome solution?
I like to make my ESPhome nodes as much independant as possibleā¦
I want to indicate CO2 values of a sensor (PPM) as a gradient from green to red with one RGB led.
Solved this by defining a custom c++ function in a .h file (e.g. gradient.h):
#include "esphome.h"
Color Gradient(Color from, Color to, float f) {
Color result;
result.r = from.r*(1-f) + to.r*(f);
result.g = from.g*(1-f) + to.g*(f);
result.b = from.b*(1-f) + to.b*(f);
return result;
and then include the .h file:
esphome:
friendly_name: ESP32-S3 T-Display
platformio_options:
build_unflags: -Werror=all
board_build.flash_mode: dio
includes:
- gradient.h
and then in the lambda:
if ((id(electricity_price).state >= 0.15) && (id(electricity_price).state < 0.30)) {
it.printf(268, 100, id(font1), Gradient(id(my_green), id(my_red), (id(electricity_price).state - 0.15) / (0.3 - 0.15) ), TextAlign::CENTER, "%.5f", id(electricity_price).state);
It works like a charm!
