Big thanks to Jesse Hills for helping work out the syntax for this. This will do an animated slideshow of GIFs on an RGB LED matrix. If you have an 8x8 panel be sure to choose small GIFs, like the ones you find on Awtrix or LaMetric devices.
The gif files can be stored in the esphome directory of your Home Assistant installation.
If you have a larger panel you can adjust the width and height and resize parameters to match your device. The slideshow will start with the second item in the list because of the first iteration of the timer loop.
time:
- platform: homeassistant
light:
- platform: fastled_clockless
chipset: WS2812B
pin: GPIO18
num_leds: 64
rgb_order: GRB
default_transition_length: 0s
color_correct: [75%, 75%, 75%]
restore_mode: ALWAYS_ON
animation:
- file: "fireworks.gif"
type: RGB565
resize: 8x8
- file: "audioviz.gif"
type: RGB565
resize: 8x8
- file: "beer.gif"
type: RGB565
resize: 8x8
- file: "alien.gif"
type: RGB565
resize: 8x8
- file: "moon.gif"
type: RGB565
resize: 8x8
- file: "sun.gif"
type: RGB565
resize: 8x8
- file: "rainy.gif"
type: RGB565
resize: 8x8
- file: "tetris.gif"
type: RGB565
resize: 8x8
- file: "animated_eye.gif"
type: RGB565
resize: 8x8
- file: "clock.gif"
type: RGB565
resize: 8x8
- file: "matrix.gif"
type: RGB565
resize: 8x8
- file: "heart.gif"
type: RGB565
resize: 8x8
- file: "christmas.gif"
type: RGB565
resize: 8x8
- file: "fire.gif"
type: RGB565
resize: 8x8
- file: "link_zelda.gif"
type: RGB565
resize: 8x8
- file: "pastel_rainbow.gif"
type: RGB565
resize: 8x8
- file: "cappuccino.gif"
type: RGB565
resize: 8x8
- file: "pacman_and_ghosts.gif"
type: RGB565
resize: 8x8
- file: "beach.gif"
type: RGB565
resize: 8x8
globals:
- id: current
type: int
restore_value: no
initial_value: '0'
- id: last_loop_time
type: uint32_t
restore_value: no
initial_value: '0'
- id: gifs
type: std::vector<esphome::display::Animation*>
restore_value: no
display:
- platform: addressable_light
addressable_light_id: led_matrix_light
width: 8
height: 8
rotation: 180°
update_interval: 16ms
lambda: |-
uint32_t current_time = id(esptime).now().timestamp;
uint32_t elapsed_time = current_time - id(last_loop_time);
// If 60 seconds have elapsed, move to the next item in the list and wrap around to the 0th item if we've reached the end of the list
if (elapsed_time >= 60) {
id(current) = (id(current) + 1) % id(gifs).size();
id(last_loop_time) = current_time;
it.image(0, 0, id(gifs)[id(current)], COLOR_ON, COLOR_OFF);
interval:
- interval: 0.4s
then:
lambda: |-
id(gifs) = {
id(cappuccino),
id(fireworks),
id(audioviz),
id(beer),
id(alien),
id(moon),
id(sun),
id(rainy),
id(tetris),
id(animated_eye),
id(ledclock),
id(matrix),
id(heart),
id(christmas),
id(fire),
id(link_zelda),
id(pastel_rainbow),
id(pacman_and_ghosts),
id(beach)};
id(gifs)[id(current)]->next_frame();
