I'm trying to enable a LED immediately after boot, but apparently they are not ready at priority -100 and I can't figure out when they are.
Consider the config below. When I press the button the LED goes red - blue - green - purple.
But on boot it just goes blue - green - purple.
Config:
substitutions:
node_name: led-test
esphome:
friendly_name: "LED test"
on_boot:
priority: -100
then:
- script.execute: update_status_led
esp32:
variant: esp32s3
flash_size: 16MB
framework:
type: esp-idf
psram:
mode: octal
speed: 80MHz
# wifi, ota, logger, mqtt omitted
web_server:
port: 80
script:
- id: update_status_led
mode: restart
then:
- delay: 500ms
- light.turn_on:
red: 20%
green: 0%
blue: 0%
- delay: 500ms
- light.turn_on:
red: 0%
green: 0%
blue: 20%
- delay: 500ms
- light.turn_on:
red: 0%
green: 20%
blue: 0%
- delay: 500ms
- light.turn_on:
red: 20%
green: 0%
blue: 20%
light:
- platform: esp32_rmt_led_strip
rgb_order: GRB
pin: GPIO7
num_leds: 3
chipset: SK6812
use_dma: True
restore_mode: ALWAYS_OFF
- platform: partition
default_transition_length: 0s
segments:
- id: status_led_hardware
to: 0
segments:
to: 1
segments:
to: 2
button:
on_press:
