I’ve a ledstrip that is triggered by a zigbee wireless rocket switch, however, I’m not able to set up static configuration so it will use some color, or white temperature based on the daytime
This is the current automation
alias: ZHA - Remote Lights - LedStrip time color
description: Adjust led strip color and temperature based on time
triggers:
- type: turned_on
device_id: 2621877605c84ad0c5c331c6d4eb7b06
entity_id: fdca0654b238874643adb4ecb7f1a703
domain: light
trigger: device
conditions: []
actions:
- choose:
- conditions:
- condition: time
after: "06:00:00"
before: "12:00:00"
sequence:
- target:
entity_id: light.ledstrip
brightness: 254
color_temp: 153
action: light.turn_on
- conditions:
- condition: time
after: "12:00:00"
before: "20:00:00"
sequence:
- target:
brightness: 254
color_temp: 400
- conditions:
- condition: or
conditions:
- condition: time
after: "20:00:00"
- condition: time
before: "06:00:00"
sequence:
- target:
brightness: 100
hs_color:
- 0
- 100
default: []
mode: single
I’ve been trying with hs_color and color_temp & brightness however when is triggered the automation the color is not set.
additionally the startup-behaviour es set to Off and those are the attributes of the entity:
min_color_temp_kelvin: 2000
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 500
supported_color_modes: color_temp, xy
color_mode: null
brightness: null
color_temp_kelvin: null
color_temp: null
hs_color: null
rgb_color: null
xy_color: null
off_with_transition: false
off_brightness: 254
friendly_name: LedStrip Light
supported_features: 40
Anyone have some idea what could be wrong or what would be the correct approach ?
BTW - I know there is Flux extension however I was never able to make it work properly, so I prefer use this static approach
