Does anyone got this working especially the RGB Stripe?
i got the led panel basically working with tuya local means on/off/brightness.
but no color temperature change.
just the very basics.
but the RGB Stripe even as it can be chosen seems to not have a valid configuration data as it does not create an entity.
i do not find an easy way in order to “scan” the device for data points so hard to help here.
if there is a config help it is appreciated
Solved
With the new Update of Tuya Local it works with all bells and whistles.
Amazing
i got a Planon 60x60 with RGB Backlight.
Software v1.0.4 (not updatet to1.0.6) should i ?
local tuya v5.2.1
I got the device name, id and local key.
I got tow entities.
1 for the main light.
1 for the backlight.
i can controll the colour of main and backlight.
but I can not switch the lights separated on or off, only together.
Would be great, if you share your config.
thanks
bg.
