Legacy binary_sensor template deprecation
Today, after updating HA I was presented with 5 repairs all with the same issue regarding the deprecation of the legacy platform: template stating I need to migrate to the modern template syntax:
I took a backup of my existing config and replaced it with the (cleaned up) provided config shown in the screenshot above, but it doesn’t work.
The config I have is:
template:
  - binary_sensor:
      - name: Teams Meeting
        default_entity_id: binary_sensor.teams_meeting
        icon:
          { if is_state("binary_sensor.meeting_state_is_in_meeting", "on") }
			    mdi:phone
          { else }
            mdi:phone-off
          { endif }
        state:
            on
          { else }
            off
          { endif }
And when checking the configuration in Developer tools, I get this error:
Configuration errors
Error loading /config/configuration.yaml: while scanning for the next token
found character '\t' that cannot start any token
  in "/config/binary_sensor.yaml", line 7, column 1
Although I have been using HA for a few years, I am not really experienced in the yaml config side of things…
See this thread - especially the first post.
The \t was bugging me, so I pasted the code into a linux box and it showed some incorrect formatting so I corrected that and now get:
template:
  - binary_sensor:
        icon:
            mdi:phone
          { else }
            mdi:phone-off
          { endif }
        state:
            on
          { else }
            off
          { endif }
You are mixing tabs and spaces inside yaml, that’s a no-no. You have to use tabs or spaces, not both.
That’s what the \t was referring to.
Agree with petro, YAML is hung up on spacing. You may have to “de-pretty” your expression.
All of your delimiters are missing their %
should be:
{% if is_state("binary_sensor.meeting_state_is_in_meeting", "on") %}
Could it be you were using an editor that decided it replace spaces with tabs?
edit: oh, I see I’m a bit late to the party :grinning:
Thanks all, I have ensured I am only using spaces in the config now. Suspected it was something like that, but posted before checking (my bad).
I have changed it to this as I think you are saying:
template:
  - binary_sensor:
        state:
            on
          {% else %}
            off
          {% endif %}
But checking the configuration gives me this error now:
found character '%' that cannot start any token
  in "/config/binary_sensor.yaml", line 6, column 12
put a | behind that line to make it a multiline
state: |
You’re missing the multi-line quote indicator:
template:
  - binary_sensor:
        state: |
            on
          {% else %}
            off
          {% endif %}
Beat you to it :grinning:
That now gives this warning:
Invalid config for 'binary_sensor' at configuration.yaml, line 18: required key 'platform' not provided
Can the warning be ignored?
template doesn’t go in binary_sensor.yaml
There are multiple examples in the thread @PecosKidd linked above.
I promise I did look there before @PecosKidd mentioned it and tried some, but couldn’t get it to work. I probably missed the | for multilines.
Thank you all!
How to do this in split yaml files? Because I get this error :
Invalid config for 'template' at entities/templates/binary_sensors/smoke.yaml, line 2: 'binary_sensor' is an invalid option for 'template', check: binary_sensor->0->binary_sensor Invalid config for 'template' at entities/templates/binary_sensors/smoke.yaml, line 2: required key 'state' not provided
binary_sensor:
  - default_entity_id: binary_sensor.rooksensor_overloop
    icon: '{{ ''mdi:smoke-detector-variant-alert'' if this.state|int(default=0) >
      0 else ''mdi:smoke-detector-variant-off'' }}'
    state: '{{ states.binary_sensor.smoke_sensor_overloop_smoke_detected.state }}'
    state: '{{ states.binary_sensor.smoke_sensor_keuken_smoke_detected.state }}'
  - default_entity_id: binary_sensor.rooksensor_zolder
    state: '{{ states.binary_sensor.smoke_sensor_zolder_smoke_detected.state }}'
you have to show how you included it.
Sure
My configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
  customize: !include customize.yaml
  # Load packages
  packages: !include_dir_named packages
#script: !include scripts.yaml
scene: !include scenes.yaml
And then in packages folder I have a template.yaml:
template: !include_dir_list ../entities/templates
And in entities/templates dir I have a binary_sensors folder with a file smoke.yaml:
binary_sensor:
use
template: !include_dir_merge_list ../entities/templates
Then name the files whatever you want and keep the content’s what you already have but add a - in front of binary_sensor:.
- binary_sensor:
  - default_entity_id: ....
You won’t be able to use sub folders, so just name it smoke.yaml and put all template entities related to smoke inside it. e.g.
- binary_sensor:
- switch:
  - default_entity_id: switch.foo
- light:
  - default_entity_id: light.foo
Thanks! That works :smiley:
