I still cannot wrap my head around the syntax of HA. “Solution A isnt supported anymore, but when you move to solution B, this no longer works” Its a struggle sometimes.
In any case. I am apparently using an ‘old’ way of doing sensors, which do not support state_class. So im trying to migrate to the new way. When I use the following, I do not see any errors in config.yaml, but I also do not see my sensor in HA. I do have other template sensors in my config. Am I breaking it by mixing old and new?
template:
- sensor:
- name: "waterheater_sensor_totaltherm"
device_class: gas
unique_id: f5846b01-aca9-4480-aa33-02d6a69bd306
unit_of_measurement: Therms
value_template: "{{ states('sensor.ch2_unit1_cumulative_gas_use') | float(0) / 39.81103633916554 }}"
# - platform: template
# sensors:
# waterheater_sensor_totaltherms:
# device_class: gas
# unique_id: f5846b01-aca9-4480-aa33-02d6a69bd306
# unit_of_measurement: Therms
# value_template: "{{ states('sensor.ch2_unit1_cumulative_gas_use') | float(0) / 39.81103633916554 }}"
