Hello, again!!!
I tried to install the code sent by colleague Mikecoscia, but I had the following error when installing by ESPHOME from HA, could anyone help me?
Hi, could you please share your whole config again? After the 2025.3 or 2025.4 update it’s unustable. I think the problem with the In Home Assistant wake word
Hi @BramNH !
Amazing work. The R2D2 is lovely. I am trying to replicate the setup with the same micro servo and I am not having good luck so far. From the pictures, I understand that you have connected the servo head to a lego piece hole directly, and then you have screwed the servo to the same piece (white) with the help of two lego flat pieces (red + brown), or have you used anything else?
Thanks for your help!
Miguel
I have only used one flat white piece, the servo head can fit in one of the holes + a small screw to secure. And one red flat piece to attached to the servo with a screw which is used to connect to the body of R2
Hi @BramNH !
Thanks for the clarifications. Not sure of fully understanding it. Just to confirm: so, you used 2 screws:
-Screw 1: red flat piece and servo hole 1 (not attached to flat white piece)
-Screw 2: servo hole 2 and connected to what?
-Servo head attached to one hole of white piece
-Flat red piece not connected with flat white piece thorough its holes
Thanks again !
Miguel
Lego pieces are not connected. Red piece is used to attach to body. White piece to head. I wouldn’t follow my design that strictly though, its not perfect.
For the white piece, use a very small screw, the servo should come with one for it.
Hi @BramNH ,
Your design is awesome, I have seen the video and it seems to work very well. From your answer it is now clear to me that you use 2 screws and their use:
Screw 1: small screw attached to the flat white piece, I have understood that you use it to join the white piece and the servo head. Do you insert it perpendicularly to the servo head, don’t you?
Screw 2: to join the red piece and the servo body. The other screw hole in the servo body is empty. For this to work, you require to attach the red piece holes in the R2D2 body (black piece).
Yes, that’s how I have it, for me it works okay. As I said not perfect. There is a little too much space between the head and body, so not a perfect fit. I also had to remove some Lego pieces from the body that I can remember.
Just try to make a solution that works best for you. This isn’t meant as a tutorial on how to make this.
Hi @BramNH,
Thanks for your quick answer. I will try to be inspired by your setup. I know it is not a perfect fit, but it is a very good starting point!
Thanks again
Miguel!
Just my picture contribution. I finally have it working ! : White piece attached to the body and the servo with screw. Green piece short screw to servo head and attached to head (with a red piece)
Is it the same as my software? Or were there updates required? Could you share if any additional steps had to be taken for the software, so this page is up to date again
It is based in your code, but I remember I got some errors, so it needed minor updates, probably due to changes in ESP version. I share my working code, with ESPHome 2025.4.2, using ATOM Echo and the same servo model as you, feeding the servo from the ATOM Echo
Hi guys!
I found a cool on device Hey R2 microwakword for my R2 unit, I could add it to the config, and works once, then I must press the factory reset button
First use: works great
second use: the servo move to 0% after the answer
third use: R2 stuck in replaying
