I am having problems with my Legrand units. I have set up some groups of lights but each time the automation runs, or I try to run them manually, I get the following message.
“Failed to perform the action light/turn_on. Cannot connect to host api.netatmo.com:443 ssl:default [Network unreachable]”.
I presume that the API connection is the one that Home Assistant uses to negotiate with the Legrand control system. I have also read that only a certain number of commands can be issued per period of time (though I cannot understand why).
Can someone explain why this is happening and how I can resolve it please? It is seriously denigrating my enjoyment of using Home Assistant!
Hi, how do I do that? I have read some info on api commands and it looks beyond my capabilities. I only use the UI of HA and have not had time to look into yaml.
Well I contacted Legrand who were completely disinterested in helping me despite providing the api for third parties. I suspect I will have to progressively move to Shelley or similar products that do not require a distant server to manage them. If only I had known before I started building the house. An expensive lesson to learn.
I heartily recommend NOT investing in (intelligent) Legrand products to anyone trying to build a connected home.
In the meantime I am stuck with automations and controls that are not working. Does anyone have a solution to help me overcome the problem?
Sorry for delayed response but have been on holiday then suffering from a virus my son gave me!
It was the lights automation that was giving problems but now I appear to have lost all the shutters. I will close this post and open a new topic.
I have also noted the discussions on the use of HomeKit so when I have time I will experiment with that as a local solution to overcome this problem but again, that will be in a separate, targeted post.
