the new version of zigbee2mqtt now support living now device with z-stack 3.
for use reset device for disconnect to gateway K4500C and connect at your zigbee coordinator ( CC2531 ecc…)
Hi @seymourddr, what rou mean by “I unplugged the gateway from the iOS Home app”? I have Android app, but I just can diconnect it from legrand account and I don’t think it’s what you mean. Many thanks
BTW: I was able to manage devices both via Bticino app and HA via Homekit, I delete HA integration and now I’m not able to readd it again.
This works with valena next true homekit?
Has anyone tried the Celiane / Valena Next with Netatmo Zigbee series from Legrand with zigbee2mqtt ?
How is the integration?
I see little functionality in the documentation of supported devices from zigbee2mqtt, but how is the responsiveness and the stability?
do you plan to release the integration for legrand with Netatmo (Zigbee)?
Thank you!
How is the integration with Home Assistant?
Can we install this along with Home Assistant in the Raspberry Pi?
Do you plan to add as an addon for HASSIO? It would be great and easy to integrate.
A quiet simple solution to integrate your shutters is via IFTTT. The legrand api is integrated with IFTTT and then you can create webhooks and trigger them via home assistant. But there is no way to read the current status.
As you said, IFTTT is very limited in usage, only a few things can be done.
I also waiting for official component, as mqtt sticks not stable
mqtt not stable ?!?! are you shure??
I use homekit too and it’s seamless
But no Energy measurement info
Yes, no Energy measurement info. And I don’t know whose problem it is, Legrand problem or Homekit controller problem?
My integration use official Legrand API and has all the features, energy meters included. Homekit base Apple api don’t have energy characteristics, only Elgato implemented custom characteristics but they aren’t used by Home Assistant HomeKit integration.
what is the cost of your license ?
Where did you get the PIN/code from to make it work in Home Assistant via Homekit controller?
Where did you find the code?
The code is behind the cover of the wall plug ( the legrand gateway)
