Lenovo ThinkCentre M900 on Wifi is not binding to 8123
I’m installing a fresh install on a Lenovo ThinkCentre M900. I did the install, configured the wireless card (will be wired when it’s in the closet). I couldn’t reach 8123.
I logged into the console and I see the 4357 bound to a docker container, but 8123 is not bound and there is no container (running or stopped) that maps 8123. I checked the logs of the running containers no errors that I can see.
I did try to see if I can remotely connect to 4357 but no, no answer there.
I verified network connectivity, I can reach out to the internet and dns works. Any thoughts?
Okay so the trick is … you can’t be on wifi only. As soon as you plug in a DHCP enabled lan it starts working.
