First time joining the community site here, my apologies if I don’t post this correctly. Looking for feedback from other users. I have been using HA on Odroid with the Let’s Encrypt add-on successfully for months now. I was most recently running with the add-on v 5.4.7. When I updated to 5.4.9, I could no longer access the HA UI with secure access. After restoring the 5.4.7 add-on backup, it works again. Is there a problem with versions 5.4.8/5.4.9, or is there a problem with my configuration? Thanks in advance!
Thanks Wally, I will investigate more when I have time.
Interestingly, my z-wave js devices stopped working correctly after I updated that add-on too, around the same time. I think there was also a HA core update that same day. I saw a recommendation to re-interview the devices. It didn’t seem to work initially, so I reverted that add-on to my previous version as well, interviewed the devices again and they are working now. I’m leaving the older add-on version running for now.
Back to the ssl connection problem, I was thankfully able to access on my local network with an unsecured connection, restore the prior Let’s Encrypt version, after which it started working again. I looked a bit at the Let’s Encrypt logs but not being familiar with them already and knowing what to expect for sunny day / rainy day logs, I didn’t see anything obviously wrong.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
