Let's Encrypt cert doesn't renew due an unicode error?
The log from the Let’s Encrypt addon:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[21:07:19] INFO: Selected DNS Provider: dns-cloudflare
[21:07:20] INFO: Use propagation seconds: 60
[21:07:23] INFO: Use CloudFlare token
  File "/usr/local/bin/certbot", line 5, in <module>
    from certbot.main import main
  File "/usr/local/lib/python3.9/site-packages/certbot/main.py", line 6, in <module>
    from certbot._internal import main as internal_main
  File "/usr/local/lib/python3.9/site-packages/certbot/_internal/main.py", line 19, in <module>
    import josepy as jose
  File "/usr/local/lib/python3.9/site-packages/josepy/__init__.py", line 40, in <module>
    from josepy.json_util import (
  File "/usr/local/lib/python3.9/site-packages/josepy/json_util.py", line 14, in <module>
    from OpenSSL import crypto
  File "/usr/local/lib/python3.9/site-packages/OpenSSL/__init__.py", line 8, in <module>
    from OpenSSL import crypto, SSL
  File "/usr/local/lib/python3.9/site-packages/OpenSSL/crypto.py", line 8, in <module>
    from cryptography import utils, x509
  File "/usr/local/lib/python3.9/site-packages/cryptography/x509/__init__.py", line 6, in <module>
    from cryptography.x509 import certificate_transparency
  File "/usr/local/lib/python3.9/site-packages/cryptography/x509/certificate_transparency.py", line 10, in <module>
    from cryptography.hazmat.bindings._rust import x509 as rust_x509
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe4 in position 3: invalid continuation byte
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I’ve tried both methods; http and dns but no difference. Any ideas how to fix or debug this? The certificate expired and doens’t renew due this error.
