Let's Encrypt conf file is broken
Hey guys,
After a restore of my Hass.io it looks like my conf file is now broken. I don’t know where to find that conf file or how to make the addon recreate it. The actual location mentioned in the logs I believe is the location within the docker container which I don’t know how to access. Any help would be greateful.
starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /data/letsencrypt/renewal/<redacted website>.conf
expected /data/letsencrypt/live/<redacted website>/cert.pem to be a symlink
Renewal configuration file /data/letsencrypt/renewal/<redacted website>.conf is broken. Skipping.
0 renew failure(s), 1 parse failure(s)
No renewals were attempted.
Additionally, the following renewal configuration files were invalid:
  /data/letsencrypt/renewal/<redacted website>.conf (parsefail)
Figured it out… basically uninstalled the add-on and re-installed it.
Hi marat! I have the same problem.
When you uninstall the add?? What is this?? How make this??
Sorry for my bad english
Could you help me???
Regards!
I don’t use the add-on, but the linuxio letsencrypt container, and I got the same error. So it does not seem related to the add-on.
