Let's Encrypt on HassOS
I almost hate posting this. Every thread I find has people debating hassio vs hass os. Talking about dockers. Has my head spinning. I’m not a linux guy. I am learning. But the debates are unnerving.
Bottom line:
I have HassOS running perfectly (at least for me) and have DuckDNS working with the ports forwarded correctly.
Now I want to secure it with Let’s Encrypt. Can anyone simply tell me how to get to get the certificate installed?
I certainly can’t do a sudo apt-get install certbot -y
I have been working on this for several days. Sorry to be so snippy.
Since you are running Home Assistant OS, you might want to use the Let’s Encrypt add-on.
… the duckdns addon already has a Let’s Encrypt option in the config - just needs setting to true and the homeassistant configuration updating to use the certificate it generates.
I had it installed. After reading the documentation again with fresh eyes, I finally understood (Sort of) what was going on. I have it running now. Thank you.
I had saw that… Just didn’t understand, Works well.
