Let's Encrypt update to 6.0.0 fails issuing cert for custom CA
Bit of an edge case here. I’m running my own internal smallstep CA, issuing certificates to machines on my local network.
Previously the Let’s Encrypt add-on worked fine, I am using the “Additional CA” package to install my CA certs into HA. My CA and intermediate certs are also in the /usr/share/ca-certificates. It was happily renewing certs, however after the update to 6.0.0 I’m getting the following error:
OSError: Could not find a suitable TLS CA certificate bundle, invalid path: /etc/ssl/cert.pem
(This appears to be a link to certs/ca-certificates.crt which seems to exist)
Any help appreciated
Logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[08:52:37] INFO: Selected HTTP verification
[08:52:37] INFO: Updating the trust store by adding the provided custom root certificate
Clearing symlinks in /etc/ssl/certs...
done.
Updating certificates in /etc/ssl/certs...
rehash: warning: skipping ca-certificates.crt, it does not contain exactly one certificate or CRL
151 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
[08:52:40] INFO: Detecting existing certificate type for homeassistant.mpkc.local
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[08:52:41] INFO: Existing certificate using 'ecdsa' key type.
Root logging level set at 0
Requested authenticator standalone and installer None
Single candidate plugin: * standalone
Description: Runs an HTTP server locally which serves the necessary validation files under the /.well-known/acme-challenge/ request path. Suitable if there is no HTTP server already running. HTTP challenge only (wildcards not supported).
Interfaces: Authenticator, Plugin
Entry point: EntryPoint(name='standalone', value='certbot._internal.plugins.standalone:Authenticator', group='certbot.plugins')
Initialized: <certbot._internal.plugins.standalone.Authenticator object at 0x7f58112f30e0>
Prep: True
Selected authenticator <certbot._internal.plugins.standalone.Authenticator object at 0x7f58112f30e0> and installer None
Plugins selected: Authenticator standalone, Installer None
Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://ca.mpkc.local/acme/acme/account/aQIKFiASzjCTUNm8niTuEENVWGVXlwx9', new_authzr_uri=None, terms_of_service=None), facf4e2aec3dafc81f8870190446f25a, Meta(creation_dt=datetime.datetime(2025, 9, 5, 17, 16, 32, tzinfo=datetime.timezone.utc), creation_host='core-letsencrypt.local.hass.io', register_to_eff=None))>
Sending GET request to https://ca.mpkc.local/acme/acme/directory.
Exiting abnormally:
  File "/usr/local/bin/certbot", line 8, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.13/dist-packages/certbot/main.py", line 19, in main
    return internal_main.main(cli_args)
  File "/usr/local/lib/python3.13/dist-packages/certbot/_internal/main.py", line 1871, in main
    return config.func(config, plugins)
  File "/usr/local/lib/python3.13/dist-packages/certbot/_internal/main.py", line 1559, in certonly
    le_client = _init_le_client(config, auth, installer)
  File "/usr/local/lib/python3.13/dist-packages/certbot/_internal/main.py", line 836, in _init_le_client
    return client.Client(config, acc, authenticator, installer, acme=acme)
  File "/usr/local/lib/python3.13/dist-packages/certbot/_internal/client.py", line 292, in __init__
    acme = acme_from_config_key(config, self.account.key, self.account.regr)
  File "/usr/local/lib/python3.13/dist-packages/certbot/_internal/client.py", line 73, in acme_from_config_key
    directory = acme_client.ClientV2.get_directory(config.server, net)
  File "/usr/local/lib/python3.13/dist-packages/acme/client.py", line 341, in get_directory
    return messages.Directory.from_json(net.get(url).json())
  File "/usr/local/lib/python3.13/dist-packages/acme/client.py", line 716, in get
    self._send_request('GET', url, **kwargs), content_type=content_type)
  File "/usr/local/lib/python3.13/dist-packages/acme/client.py", line 658, in _send_request
    response = self.session.request(method, url, *args, **kwargs)
  File "/usr/local/lib/python3.13/dist-packages/requests/sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.13/dist-packages/requests/sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.13/dist-packages/requests/adapters.py", line 616, in send
    self.cert_verify(conn, request.url, verify, cert)
  File "/usr/local/lib/python3.13/dist-packages/requests/adapters.py", line 303, in cert_verify
    raise OSError(
    ...<2 lines>...
An unexpected error occurred:
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This appears to have been logged by another user as an issue.
https://github.com/home-assistant/addons/issues/4425
And your contribution has resulted in the fix being ready for deployment. Thanks.
This has now been fixed in 6.0.3, and works again for me.
Thanks for the prompt fix.
Matt
