Let'sEncrypt "You may need to use an authenticator plugin that can do challenges over DNS."
I am setting up a new HAOS server on Proxmox, with the intention of migrating from my existing HA core Docker setup. I have installed and configured the LetsEncrypt add-in but when I tries to obtain a certificate it fails with this error:
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
I selected port 89 as the verification port, and have forwarded this to the HAOS server.
Any ideas?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
s6-rc: info: service legacy-services successfully started
[18:47:19] INFO: Selected http verification
[18:47:19] INFO: Detecting existing certificate type for mydomain.ddns.net
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[18:47:19] INFO: No certificate found - using 'ecdsa' key type.
Account registered.
Requesting a certificate for mydomain.ddns.net and *.mydomain.ddns.net
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
I just remembered something at the back of my mind about LetsEncrypt only being able create/renew certs over port 80, so I changed the config of the LetsEncrypt add-on to use port 80, then forwarded that port on my router to the HAOS server. I get the same error.
