I created a feature request for Level Lock Integration. Please Vote!
https://community.home-assistant.io/t/level-lock-integration/210009
I’ve got a solution that seems to be working (albeit a little fragile) to control the Level Lock from Home Assistant. It’s not the direct integration that we would all want to see, but given the limitation that the lock itself is BLE only, this will do.
Here’s how it works:
Lock Proxy
They are as follows:
Obviously this can get to be fragile if somehow the states get out of sync, but it does work as a band-aid.
Hope this helps!
Hi Matt,
I am not sure if I understand how this works. How do you bring the Level Lock to your HASS?
Oh, I didn’t at all. I’m simply making a fake switch that is then able to be seen in HomeKit, then using HomeKit automations to link the fake switch and the Level Lock.
OIC, I just wonder how quickly can the lock response via Homekit automation? I will give it a try, thanks for the idea.
It would be great if we can have true integration between HASS and Level Lock or all Homekit BLE devices. Unfortunately, I have no technical knowhow to understand why it is so difficult to create a generic BLE controller.
The whole thing takes about 4 seconds round trip, from the time I activate the Proxy Lock until the lock is unlocked. Then probably another 1-2 seconds to receive the notification from Homekit that the event happened.
Here’s a little preview of how it works (this has been sped up to 2x real-time). The screen recording was taken when I was away from the home and on an LTE network.
I thought the same but I saw a video of a guy on youtube cutting a standard bolt in half…They’re all hollow lol.
With HomeKit Integration, you can setup location based settings and it will unlock as you approach. You can manually lock/unlock, use the HomeKit integration, or through the Level Lock app. I’ve had one for 3 years, and they are really nice. I’ll integrate it with Alexa, or Home Assistant when it becomes available.
Hi Matt,
Can i just clarify a couple of things about your solution…
You state
- Use HomeKit Bridge to bring that switch on over to your HomeKit instance
Does this mean that you are simply running an instance of https://homebridge.io/ on your network and that you don’t actually have a HomeKit enabled hub?
I was under the impression that the Level Lock can natively integrate with HomeKit and to so so, you had to have a HomeKit enabled hub like the HomePod mini. Does your solution need a HomeKit hub (like HomePod mini)?
Can you please correct my understanding of your solution:
Lock Proxy
Here is where i have questions:
You state:
2. Use HomeKit Bridge to bring that switch on over to your HomeKit instance
Is the ‘HomeKit Bridge’ the https://homebridge.io/ i mentioned above or a hub like Homepod mini?
Is the ‘HomeKit instance’ the integration within Home Assistant?
3. Set up automations in the Home app to handle different states.
What is the ‘Home’ app in this instance?
Thanks in advance for your help
Hi Thomas,
Are you using Homekit’s own location detection to automate your lock? Or, are you using another kind of mechanism to determine your location?
I tried the Homekit’s location detection as well as the HA companion app, but found it works only 90% to 95% of time. It is quite annoying when the lock unlock too early, before I approach my house, or even worse when it unlock suddenly, after I entered my home and locked my door. Do you have similar issue?
Hi Michael,
I do not speak for Matt but just to share my experience.
What I have done is :
I also created a HA script and exposed it to Homekit so that when I say “Hey Siri, Sesame open the door” at home, it will unlock the door without the need to confirm on my iPhone.
Actually, my HomeKit App asks me if I want to run the automation to unlock the door and turn on certain devices. However, the LevelLock will unlock itself only when I am about 15 feet (that’s a rough estimate…) from my door.
Also, I stated HomeKit Integration above, but actually meant to say HomeKit App. I am hoping it will eventually move to HomeAssistant as it would be nive to be able to check entity “states” at certain intervals to ensure someone didn’t come in late and leave the door unlocked. I have a couple of kids and an elderly parent living with my wife and I. Checking up on them (especially the elderly parent) constantly is ROUGH… LOL
Now that the new Level door lock officially supports Alexa, is there any chance that it could be integrated into HA?
Does that come with an open local api?
As much as it pains me I would advise anyone to not waste your time with Level until they come out with a z-wave or wifi version. While this product is gorgeous (no one knows you have a smart lock), it is clearly not ready for market. I tried it for about 2 months and despite having an Apple HomePod located just 5’ away from the lock, it lost connection all the time and would only work about half the time. Even using the Level app would fail often while standing next to it.
I just sent it back and purchased another August smart lock. The one I have had for 3 years has had zero failures whereas the Level lock failed 50% of the time.
Agreed. Until there is a Z-Wave version no deal for me. Maybe the audience is supposed to be less technical so HomeKit? Trying to get a wider audience?
Hi all, and apologies for being dense here. Just getting caught up with the Level / HASS threads here and I’m having trouble at this step… can anyone provide a link to tactical documentation for achieving this? I have set up the input_boolean
and have been successfully using the HomeKit integration for some time, but how do I actually get said input_boolean
to appear in HomeKit? What steps do I need to take to “bring that switch on over” / “expose it” as suggested?
Is it just homekit.filter.include_entities
Thanks in advance!
Update!
Please disregard. Turns out my Bridge integration was actually malfunctioning. This solution works well for me now! A bit of an extra delay, yes, but gets the job done perfectly!
Level now supports Ring integration in addition to HomeKit and Alexa.
