Please add support for the fan controller switch to the leviton decora wifi integration. Since all the switches are loaded in home assistant as light entities, voice commands to turn on the lights in a room, also turn on the fan.
I have this fan controller as well and have started poking at the code a bit. I’ve had some basic software development experience but I’m still pretty green as an open source project contributor though, so I’m still learning the dev environment and how to do the testing required to generate a pull request. Once I get that figured out though, the actual programming for this seems like it should be fairly straightforward.
Any luck here?
Also requesting the same. I have a D24SF-2RW Smart Fan Controller controlling my fan (lights are on a different switch) and instructions say to add it as a light in configuration.yaml file. So it shows up as a light with my Homekit integration.
