Leviton plug dimmer integration
Does anyone know how to integrate the Leviton D23LP-2RW with HomeAssistant? I scanned the QR code on back and it integrated with HomeKit in less than a minute. I did a factory reset and then put it in pairing mode. There are three Leviton integrations and I tried the first one which scanned a wave but didn’t find anything.
What’s the trick to get this guy added to my HA?
I don’t know anything about the dedicated integrations but if it works with HomeKit then you should be able to add it to Home Assistant using the HomeKit Device integration:
The only caveat being that devices added via dedicated integrations may have more features than HomeKit Devices. e.g. For Lifx lights the dedicated Lifx integration allows changing attributes when the light is off, HomeKit does not.
Thanks, but I hate relying on Mapple. However this worked. Too bad it wasn’t automated.
“Discovered”.
