LG webOS - Failed to call service. code = 1006
Hi, suddenly I start having this error on the LG webOS and I cant control de TV.
Failed to call service media_player/toggle. code = 1006 (connection closed abnormally [internal]), no reason
This is the log
Logger: homeassistant.components.websocket_api.http.connection
Source: components/webostv/media_player.py:422
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10:00:20 AM (1 occurrences)
Last logged: 10:00:20 AM
[1585503512] code = 1006 (connection closed abnormally [internal]), no reason
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 827, in transfer_data
    message = await self.read_message()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 895, in read_message
    frame = await self.read_data_frame(max_size=self.max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 971, in read_data_frame
    frame = await self.read_frame(max_size)
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 1047, in read_frame
    frame = await Frame.read(
  File "/usr/local/lib/python3.8/site-packages/websockets/framing.py", line 133, in read
    data = await reader(length)
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 723, in readexactly
    await self._wait_for_data('readexactly')
  File "/usr/local/lib/python3.8/asyncio/streams.py", line 517, in _wait_for_data
    await self._waiter
  File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 848, in _read_ready__data_received
    data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 135, in handle_call_service
    await hass.services.async_call(
  File "/usr/src/homeassistant/homeassistant/core.py", line 1445, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
    await self.hass.helpers.service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 593, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 630, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/components/webostv/media_player.py", line 92, in wrapper
    await func(obj, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/webostv/media_player.py", line 367, in async_media_play_pause
    await self.async_media_play()
  File "/usr/src/homeassistant/homeassistant/components/webostv/media_player.py", line 422, in async_media_play
    await self._client.play()
  File "/usr/local/lib/python3.8/site-packages/aiopylgtv/webos_client.py", line 936, in play
    return await self.request(ep.MEDIA_PLAY)
  File "/usr/local/lib/python3.8/site-packages/aiopylgtv/webos_client.py", line 626, in request
    await self.command(cmd_type, uri, payload, uid)
  File "/usr/local/lib/python3.8/site-packages/aiopylgtv/webos_client.py", line 616, in command
    await self.connection.send(json.dumps(message))
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 555, in send
    await self.ensure_open()
  File "/usr/local/lib/python3.8/site-packages/websockets/protocol.py", line 803, in ensure_open
    raise self.connection_closed_exc()
websockets.exceptions.ConnectionClosedError: code = 1006 (connection closed abnormally [internal]), no reason
Anyone having this issue?
I’m also having this issue. Any solutions? A server restart fixes the problem but it happens every couple of days at the moment.
