Hi everyone,
I’d need some help.
I’ve had this working perfectly before, but recently, it fell off my HA map and I haven’t been able to get it to work again. I’ve removed the integration but when trying to reestablish it, I get the error below. The TV already has a static IP, which I’ve also tried changing but it did nothing. The LG app on my phone works fine. I’m not sure what to try.
Thanks!!
Logger: aiohttp.server
Source: components/webostv/__init__.py:143
First occurred: 12:02:53 PM (2 occurrences)
Last logged: 12:07:31 PM
Error handling request
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 138, in read_http_response
status_code, reason, headers = await read_response(self.reader)
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/http.py", line 120, in read_response
status_line = await read_line(stream)
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/http.py", line 194, in read_line
line = await stream.readline()
File "/usr/local/lib/python3.10/asyncio/streams.py", line 525, in readline
line = await self.readuntil(sep)
File "/usr/local/lib/python3.10/asyncio/streams.py", line 617, in readuntil
await self._wait_for_data('readuntil')
File "/usr/local/lib/python3.10/asyncio/streams.py", line 502, in _wait_for_data
await self._waiter
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 854, in _read_ready__data_received
data = self._sock.recv(self.max_size)
ConnectionResetError: [Errno 104] Connection reset by peer
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/webostv/config_flow.py", line 98, in async_step_pairing
client = await async_control_connect(self._host, None)
File "/usr/src/homeassistant/homeassistant/components/webostv/__init__.py", line 143, in async_control_connect
await client.connect()
File "/usr/local/lib/python3.10/site-packages/aiowebostv/webos_client.py", line 73, in connect
return await self.connect_result
File "/usr/local/lib/python3.10/site-packages/aiowebostv/webos_client.py", line 105, in connect_handler
main_ws = await asyncio.wait_for(
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 445, in wait_for
return fut.result()
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 650, in _wrap_awaitable
return (yield from awaitable.__await__())
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 659, in __await_impl_timeout__
return await asyncio.wait_for(self.__await_impl__(), self.open_timeout)
return fut.result()
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 666, in __await_impl__
await protocol.handshake(
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 326, in handshake
status_code, response_headers = await self.read_http_response()
File "/usr/local/lib/python3.10/site-packages/websockets/legacy/client.py", line 144, in read_http_response
raise InvalidMessage("did not receive a valid HTTP response") from exc
websockets.exceptions.InvalidMessage: did not receive a valid HTTP response
