Hi I just cannot get this new integration to work on RPI 3 / Buster / Docker
I have this in my configuration.yaml;
webostv:
- name: Living_Room_TV
host: 192.168.1.5
notify:
I have removed all old notifications but I just get these errors;
‘2020-02-18 10:57:22 ERROR (MainThread) [homeassistant.setup] Error during setup of component webostv’
‘Traceback (most recent call last):
File “/usr/src/homeassistant/homeassistant/setup.py”, line 170, in _async_setup_component
hass, processed_config’
‘File “/usr/src/homeassistant/homeassistant/components/webostv/init.py”, line 99, in async_setup
await asyncio.gather(*tasks)’
‘File “/usr/src/homeassistant/homeassistant/components/webostv/init.py”, line 110, in async_setup_tv
client = WebOsClient(host, config_file)’
’ File “/usr/local/lib/python3.7/site-packages/aiopylgtv/webos_client.py”, line 67, in init
self.load_key_file()’
’ File “/usr/local/lib/python3.7/site-packages/aiopylgtv/webos_client.py”, line 94, in load_key_file
key_dict = json.loads(raw_data)’
File “/usr/local/lib/python3.7/json/init.py”, line 348, in loads
return _default_decoder.decode(s)
’ File “/usr/local/lib/python3.7/json/decoder.py”, line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())’
‘File “/usr/local/lib/python3.7/json/decoder.py”, line 355, in raw_decode
raise JSONDecodeError(“Expecting value”, s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 2 column 1 (char 1)’
Has anyone any ideas, I have read the other threads on issues with the new webostv but none seem to answer my problem.
