LIA (Lily agent)& the HA-FSM Standard (v0.9.2)
This is a fantastic project! Transitioning from “Vibecoding” (chaotic, prompt-dependent logic) to a structured Finite State Machine (FSM) approach is exactly what the Home Assistant ecosystem needs for professional-grade reliability.
Here is an English version of your post, adapted to maintain your professional yet approachable “Nordic” tone while hitting all the technical high notes for a global audience.
:rocket: Taming AI Chaos with LIA & the HA-FSM Standard (v0.9.2)
Moin everyone!
I’ve been following the recent discussions around MCP servers and Claude Code. While “Vibecoding” is a blast for rapid prototyping, it’s often a curse for high-availability Smart Homes. We’ve all been there: the AI generates a “working” automation that eventually collapses into a mess of conflicting triggers and delay loops.
To fix this, I’ve been developing smarthomelily—originally a tool for my colleagues to end their YAML chaos, now evolved into a technical framework: the HA-FSM Engineering Standard.
1. The Strategy: FSM over “Vibecoding”
The goal of the standard (currently in v0.9.1 Public Preview) is to move away from unstable “Trigger-Action” piles and toward Finite State Machines (FSM).
  • Centralized State: A dedicated input_select tracks exactly where the system stands (and survives restarts).
  • Hardware Realism: Built-in logic for physical constraints like Duty Cycle (DC) and Carrier Sense (LBT)—crucial for Homematic and Zigbee stability.
  • Idempotency: Commands are only sent when a state actually changes. This protects your airtime and your nerves.
2. Meet LIA (Lily Intelligence Agent)
To save you from digging through documentation all day, I built LIA. Technically, LIA is a specialized Bash wrapper around Claude Code, optimized specifically for HAOS (Home Assistant OS):
  • CLI Power: LIA runs via SSH/Terminal directly on the host (the “final boss” level of integration).
  • Embedded Expertise: On startup, LIA automatically loads the FSM standard as context. She doesn’t “guess” your config; she audits your YAML against FIL-Level (Maturity) and flags anti-patterns like hardcoded delays.
  • Safe Workflow: Commands like lia fsm validate run a ha core check before anything is written to your production config.
3. The Vision: The LILY-Agency
This is currently a solo project in the “Roots” phase, but the LILY-Agency is already taking shape in the background. Think of it as an “AI Architecture Firm” for Home Assistant: multiple specialized agents working hand-in-hand, following FSM norms, featuring a graphical drawing board and automated monitoring.
All local, all Open Source.
The project is a work-in-progress (v0.9.1/v0.9.2), so please be kind—it’s still a construction site! If anyone wants to chat about FSM, high availability, or running AI agents in the terminal, let’s connect.
Cheers from Northern Germany,
smarthomelily (Professional Home Automation Patterns)
lily-agent
HA-FSM-Engineering-Standard
[ Lily Agent KI im Smart Home](https://www.youtube.com/watch?v=YumVQ0waLZo&t=8s
community.simon42
Nice idea, but why putting it behind a language wall? :thinking:
You don’t want people to find it and use it? :face_with_monocle:
You’re absolutely right — that feedback actually stuck with me! I originally built this just for myself, so everything was in German. But friends kept telling me I should share it with everyone, so here we are: I’m currently translating both LIA itself and all documentation to English. Version 0.9.9.0 will be fully bilingual (DE/EN) and should be up on GitLab and GitHub in the next few days.
Hats off to you!
That will be awesome.
Thanks, we’ll see when it’s finished and you’ve all formed your opinions.
