Hi!
I am using a Life Pro AC Inverter through Wifi with an android app named INVmate II
There is any chance in order to integrate this climate with home assistant using HACS GreeClimateComponent or other intergration?
If yes, how can I do this. I tried the default instalation through HACS and the default configuration which contains:
platform: gree
name: AC Living Room
host: 192.168.0.212
port: 7000
mac: "BC:FF:BB:CC:E7:F5"
target_temp_step: 1
But I always get this error when I restart HA:
Error while setting up gree platform for climate
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 250, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.8/asyncio/coroutines.py", line 124, in coro
res = func(*args, **kw)
File "/config/custom_components/gree/climate.py", line 118, in async_setup_platform
GreeClimate(hass, name, ip_addr, port, mac_addr, timeout, target_temp_step, temp_sensor_entity_id, lights_entity_id, xfan_entity_id, health_entity_id, powersave_entity_id, sleep_entity_id, eightdegheat_entity_id, air_entity_id, hvac_modes, fan_modes, swing_modes, encryption_key, uid)
File "/config/custom_components/gree/climate.py", line 165, in init
self._encryption_key = self.GetDeviceKey().encode("utf8")
File "/config/custom_components/gree/climate.py", line 247, in GetDeviceKey
return self.FetchResult(cipher, self._ip_addr, self._port, self._timeout, jsonPayloadToSend)['key']
File "/config/custom_components/gree/climate.py", line 230, in FetchResult
data, addr = clientSock.recvfrom(64000)
socket.timeout: timed out
Any advices?
Thank you in advance!
