This has worked great until about a week or two ago when it still pulses and strobes, but it doesn’t change color. I have another automation that in teh morning flashes yellow and this doesn’t work either. I’m not sure whats going on.
I’ve had this problem too - lifx.effect_pulse used to change the color on the lamp (eg., color_name: blue) but since HA 2021.4 this doesn’t work for me.
I get that it’s the lifx component in home assistant. I’m wondering if you have a way to make it work for now? Ive found that the following works in node-red with lifx.effect_pulse. hs_color is the only color variable that seem to work for lifx services.
Were you able to find the file where the debug code goes? I assume it’s light.py for the lifx integration but even using scp I can’t find anything related to lifx. I feel like there are still areas of the OS file system that I haven’t found how to access just yet.
