Hi all,
I’m new to automation here, but familiar with home assistant. Just looking for some help on my first real automation setup. Any thoughts would be appreciated!
I have a room where one half is a laundry room and the other is used as a gym. Inside the laundry room I have a normal overhead light and in the gym area there are 2 Hue lights. I have a motion sensor in each area. The motion at the door turns on the Laundry room light by turning on the switch that has a shelly device in it. The motion around the corner turns on 2 Hue lights in the gym. The light switch that I have a shelly device in that controls the power to both areas. I keep this switch on at all times.
I have an automation setup for both areas to turn on with motion. This works fine, however when the 10 minute after motion timer switches off in the Landry room this means the gym lights go out too. How can I keep the 10 minute timeout for the Laundry area but only have the Landry light turn off if the gym lights are also off? I have the gym lights set at 90 minutes after occupancy is detected.
Laundry Motion Automation
alias: Laundry Room Motion and light
description: Turn office lights on/off on motion.
use_blueprint:
path: homeassistant/motion_light.yaml
input:
motion_entity: binary_sensor.laundry_room_motion_occupancy
light_target:
area_id: laundry_eoo
no_motion_wait: 600
Gym Motion Automation:
alias: Gym Motion Activated Lights
use_blueprint:
input:
motion_entity: binary_sensor.gym_motion_occupancy
light_target:
entity_id: light.gym
no_motion_wait: 2700
